Holds an emergency code behind a scratch panelWhat does the card do?
I've had Ghost installed this morning on my bus by https://www.advanced-incar.co.uk/
Slightly disappointed that you can only use 4 or 5 buttons to enter the immobiliser sequence, I thought I read you could pick any button at all on the wheel or dash.
I haven't enabled the Bluetooth feature, seems a backwards step to me.
View media item 1415
As @Davenjo says.......different fitters will choose different buttons for your use.
4 to 20 numbers..... just need to remember which ones!!
It's not down to the fitters its what the ghost sees, most of the buttons on my wheel didn't work my installer tried them all, he said it's down to the canbus and software on the vehicle
That's what my guys said, you could use the volume buttons but he advised against that as obviously it alters the radio volume too.
I played/play a lot of classic arcade games (hence the forum name) and I was desperate to use UU DD LL RR (some of you may remember that classic button config) as my starting combination, alas it wasn't to be.![]()
You do get used to it - it's second nature for me now.Brilliant, I've got RetroPie ready to go in my van, kids are never to young to start playing games
As an aside, I've forgotten to input the Ghost code every single time so far today, what a plonker.![]()
Autowatch have responded to my query and apparently (describing the T6 as a bit of an oddball in this respect) there is no set pattern as to which buttons will work on our vans, i.e. what works on one may not work on another - guessing this may be down to model variants and spec??I wasn't aware of the 4 or 5 button limitation - guess I have just been lucky with my choice of buttons (I've written to Autowatch to confirm which buttons)?? Even so, with the code being a sequence of between 4 and 20 buttons the possible combinations is massive - using a sequence of just 5 buttons would still give over 3000 possible codes.
PS. Your picture sent me into a bit of panic looking for my card - went through all of my vans documents and various other locations around the house several times before I realised I'd buried it in my wallet - doh!!!
