Wow that takes me back, first time I've been on the old forum in years! Cracking detailed post from Glitch, wonder if he's on here now?This might help - Swing Out Table How to - VW T4 Forum - VW T5 Forum
I'd appreciate an update as I'm planning to do the same to mount a fire extinguisher.
Chill out lad, I used 4mm self tapping wing screws 40mm long and it's solid
@Mccoatup thanks for this. Hadn’t thought of using rivnuts (already have a tool and fixings for this). My clamp and leg (From Slidepods) were supplied with self tapers. May try these first, knowing I can use Rivnuts if it’s not secure EnoughI fitted the Chippy's clamp yesterday, using M6 Rivnuts, (needs a 9mm hole drilled). You can see the position I've mounted it in the photo. I don't think it's ultra-critical - I just Googled around for pics of other people's first. The rivnut tool from eBay came with 10 M6 rivnuts. There does seem to be around 60mm space behind the holes, so not too much to worry about. I'm using the Reimo table leg that I also use with my main table which is stored in the sliding door. Either table can then fit on the other Chippy's clamp mounted under the back seat. I made my own small table from an old one I cut down, routed and edged. (Excuse to buy a new router!) It has an M10 fixing which is a shopfitting accessory. All stable enough for me to operate my laptop on from the passenger seat or the rear seats. It also swings out of the van to act as the all-important drinks table - To be road tested at the Lime Burners Inn/Campsite this Sun-Tue!
View attachment 78000 View attachment 78001 View attachment 78004 View attachment 78002 View attachment 78003 View attachment 78005
Ordered mine from Slidepods but I believe the leg and brackets are Dometic. The leg can be stowed behind the passenger seat but it doesn’t sit flush due to how far back it needs to be. - I may just remove mine when in transit. I wanted to fit my bracket higher on the B pillar but couldn’t as had to avoid the switch for LEDs. Nervous about drilling the holes so only gone with self tapers for now. If it’s not secure enough I’ll fit rivnuts laterThink this will be my next job. Whats the best quality leg to get? I assume the leg stays swung round and stowed behind the passenger seat when not in use?
I got the Kiravans one as it’s look more sturdy and I wanted to be able to choose the table top I wanted. Although I haven’t got one yet.Going to add a swing out table for passenger to use when van closed up, and for all to use when it's nice etc
There's two types I've seen but in the best Harry Hill fashion,which one is best value
Kirivans at £65
Kiravans Pro 360 Table Leg - Black Edition
Introducing the Kiravans Pro 360 Campervan Table Leg. Our solution for campervan owners seeking a versatile and premium table leg kit, designed with utmost precision. Designed and manufactured right here in Yorkshire, the Pro 360 is the result of years experimenting with dozens of other table...www.kiravans.co.uk
Or just kampers for £95
Cranked Aluminium Table Leg
Height of the leg: 710mmHeight of the leg from floor to underside of the table with bracket: 715mmLeg Arm length: 400mm, or 405mm when mounted with the bracket.Bracket sizes: 130mm x 95mm x 45mm (70mm with knob)www.justkampers.com
I prefer the look of the second one but is it worth 50% more because of any additional usability?
Fiiiiioghtttt!
