I’ve done the wiring side of this conversion quite a a few times now, and please be aware that there is no such thing as a plug and play loom, I have considered making a full retrofit loom kit as it seems to be quite a popular conversion.
How much extra wiring involved depends on a few things.
Firstly, the original spec of your van.
Secondly, What you want the finished spec to be.
No matter what, you need to run some wiring from the BCM to the rear left hand side, and unless your van is or is going to be completely stripped out, then don’t even consider trying to run the wiring anywhere other than up and along the roof, it is so much easier and will save you countless hours.
I've seen some horrific attempts at this conversion, many done by so called “proper” camper conversion companies. Everything from bonkers, to downright dangerous.
You DO NOT need any relays, you do not have to cut into the lighting or sidelight loom, although it you want to illuminate an internal release button on the tailgate itself then you can take a supply from the number plate lamp using genuine connectors.
When done correctly all control and power switching is carried out by the BCM only.
if anyone needs any help let me know,
