See post #4.Thank you, is it possible to swap the connector plugs from the barn door loom on to the tailgate loom ? Or is it not long enough, I notice all the wires are white how do you know what goes where?
Are you sure the rear screen connects to Pin 73 of the white plug (B)? I've just been looking at my BCM and noticed there is no male connector of the BCM side, which is bottom left of the right hand side of the socket B in BCM. My BCM is 087 and I've also checked other versions up to 090 and none have a male connector in that space. Would you be able to double check or share images?Connecting the Heated Rear Screen.
This sounds easy but it was a pain. You need to change the heater controls for a matching unit but with the extra button for the heated rear screen. This is simply plug and play and no wiring is needed. It uses CAN to send a message to the BCM to turn on the rear screen or not.
I brought a unit from an old Golf for £10 and took minutes to swap over.
Using VCDS, go to Module 9 Central Electrics and enable Byte 15 Bit 7 Heated Rear Window installed.
You can check with VCDS through adaptions if the switched is pressed and recognised by BCM.
You now need to run 1x 2.5mm^2 cable from Pin73 of the white BCM plug to Pin 17 (check, it could be pin16). I'm assuming you already have the earth cable attached or you won't have the brake light or number plate lights.
I couldn't find the correct terminal to go in the BCM. It's the largest size pin 6.3 mm wide. If anyone knows where to get this terminal, please post on here. I used a pin from a BMW who I work for, but it doesn't click in correctly.
Pin 63 - white connector.the rear screen connects to Pin 73
Thanks, very much appreciated. Just about driving myself mental on google trying to find an answer.Pin 63 - white connector.
For T6
And, it's the same for T5.1.![]()
T6 - Heated Rear Window Wiring Diagram
Heated Rear Glass Circuit Diagram Covers tailgates and barn door variants VIP Membership is required to download this documentwww.t6forum.com
@Littleblackflash @mmi Ok I found what T17o Pin 2 is for. It's the interior release switch and bulb illumination for the tailgate on track 190 to track 15, shown below. I have been through all the wiring diagrams from alarm, locking and lighting and can't find track 15 on any other documents to find its termination point. Do either of you know what it is? e.g. does it connect to BCM?
Thx fella. Thats the last piece of my jigsaw solved.Track 15 terminates T73b/4 on the BCM. You can pick this circuit up behind any illuminated switch
I have collected all the coding required just need to program through VCDS. I wanted all the wiring done at once, so I can code it all at the same time. Garage being kind enough to let me play with their computer, so don’t want to waste their time. So will find out next week.Deaks is right. It's only needed if you want the button to illuminate, it should still work as normal without it. I read somewhere that some owners connected the switch illumination to the number plate lights, but obviously this won't dim when you dim all the other controls but it's an easier job.
Did you get your rear wiper working?
Thanks for the information Dave. How is your tailgate now, have you noticed any fatigue in the hinge area? Where did you get the information from that a genuine tailgated van has a stronger/thicker construction around the tailgate hinge mounting area?
I have a T5.1 that was converted by a previous owner from barn door to tailgate. I installed upgraded gas struts and a Fiamma bike rack a couple of years ago. I recently noticed fatigue in the hinge area and a small split next to the hinge. From what you mentioned, I'm relating that to the potential weakness in that area with the load and conversion? I do notice a slight flex in the roof/hinge area when closing the tailgate on initially pulling against the resistance of the struts. I also noticed some rusting in the hinge bolt area inside, where the tailgate conversion may have caused fatigue and moisture ingress??
Funnily enough I checked for fatigue only this weekend gone, and found none. Couldn’t see any flexing either and I’m using hefty struts for my Cali blind / chair-holder trim-piece.Should I be worried about excessive flexing/fatigue or has everyone else had no problems with this?
Ah ok that's good to know mateFunnily enough I checked for fatigue only this weekend gone, and found none. Couldn’t see any flexing either and I’m using hefty struts for my Cali blind / chair-holder trim-piece.
There are lots of videos on YT on how to read VW wiring diagrams, I did try to find the one I used and post the link but didn’t recognise any of the hits. As far as connection 10 & 23 are concerned you will need to solder a joint with the wire already present and for the one empty all you need to do is fill the pin slot with the correct size of pin. Hope that helps.Hey guys, just read every page and found an issue I don’t think I’ve came across! (So likely my fault Haha)
I’ve started the tailgate swap on my 2017 (66 plate) transporter. Like most people got 99% of it completed but not the release handle / wiring side. I’ve paid to become a member on here to access wiring etc but still difficult for me to understand.
Few issues I've got… if anyone can give me definitive help to get this sorted I ’ll gladly send them a drink via PayPal!
- I naively thought the brand new tailgate harness I had purchased would plug into the new one, obviously we now know it doesn’t. I used the old barn door loom as a guide, cut and joined the wires to make a plug and play oem harness connecting what I can but I’m left with the wires from what originally plugged into the central locking motor, where do they go?
- adding the 2 wires to the bcm. I’ve purchased the pins from VW and checked the plug, seems like I need to connect to pin 10 and pin 23 on the BCM, I checked and pin 10 is empty but pin 23 is already used???
- When I add the wires to pin 10 / 23 where exactly do I connect them to?
I’d really appreciate any help if anybody knows and as said, gladly pay for the knowledge!
I created this table for my T5.1 Barn Door to T6 Tailgate conversion. In your case ignore the T5.1 column, only the Pin Number and T6 wire columns will be relevant. The numbers should correlate directly with pin and wire numbers on your tailgate. The coding can be found on previous posts on this thread. Good Luck.Hey guys, just read every page and found an issue I don’t think I’ve came across! (So likely my fault Haha)
