Hi, I think my lead acid leisure battery is on the way out so I'm considering the move to lithium.
I'm not 100% sure on the workings of my current set up so I'm after some advice on what would need upgrading. Current setup is:
Hook up point
CBE cb516 charger
Lead acid leisure battery 100ish a/h
Victron mppt 75/15
Sterling Battery to Battery 1230 (I think)
Starter Lead acid battery
Alternator (Van is a 220 6.1 150bhp with stop/start)
So for an upgrade to a 100ah lithium battery I'd need the battery plus an upgraded battery charger? The sterling, as far as I'm aware, can be programmed for lithium? And it's the alternator up to the job?
Any recommendations on which way to go. I could do with a charger similarly sized to the CBE as it's installed in a fairly small cupboard.
Thanks.
