Battery dead after working in the van
EDIT: 2021 refresh
The 2021 line-up for EHU battery chargers is:
5A CTEK MSX 5.0 - 5A CTEK MSX 5.0
10A NOCO GENIUS10 - NOCO Introducing GENIUS10,
15A Victron IP65 BSC - Victron Energy Blue Smart IP65 Charger
30A Victron IP22 BSC - 30A Victron IP22 BSC
@Dellmassive can the Genius 10 also be used as a booster if your battery is flat or is it just a charger, all be it a great one?
Booster NO, Charger yes.
so if your battery is flat . . . and you have EHU around a 20-30min charge should be enough to start the van (10A charge rate)(no internal battery)
a booster is for total remoteness with no power . . . it will just start from its own internal lithium battery pack.
Thanks Lee, can you recommend a booster, I have a Noco one although it’s not enough as it’s the GB40?
Sure... gb70 or gb150...
@Dellmassive just got the Nobo Genius10, great shout.
It’s now sat connected to the van doing it’s stuff and will be connected when the van is sat on the drive for weeks.
Cheers Lee.:thumbsup:
