I have a normal household 32 inch that we don't use. I'm having a leisure battery installed next week by @travelvolts with an inverter. Will a 300 w inverter run a household tv? If so then all I need is an arial.
You Sir are on of Englands finest.Yawn-a-Rama, football.
However, @Lord Mfwic, because i’m such a fine sort of chap, since I have a solar panel hooked up to my system, I could always take one for the team and let you run it off my system should you need to.
I wonder if the unit that @Loz has would work? Shame he’s not going though.Recommends for a very good mobile freeview arial required please. Or anyone who already has one who can bring it along?
Bear in mind there are lots of trees.
Like to share the link ?I’ve just bought a usb powered mobile aerial that gets good reviews. We’ll find out next week!
I meant that I’ll be bringing it with me so we’ll be able to see if it’s any good.
Looks a good piece of kit. If you're happy to bring it with you that will be great.I meant that I’ll be bringing it with me so we’ll be able to see if it’s any good but here’s the link
Wsky TV Aerial - 50 Miles Digital Freeview HDTV Indoor Antenna with Detachable Amplifier Signal Booster, Ultra-Thin And High Reception, Super Long Cable-Super Fun and FREE for Life, Portable,Black … https://www.amazon.co.uk/dp/B06Y6427MX/ref=cm_sw_r_cp_api_s.vnBbQNYBJEF
You’ve clearly put some thought into that, bet you have a sketch and everything. Is it to scale?Whoever does get to our pitch first please consider the best direction for all members..
A hollow square.. with majority of awnings on left.
If the weather is good then a event shelter maybe used for cumunital (sp) area.
Or a map on the dining room table, loads of 3d vans and big stick to push them around with replicating the aramada on camperjam.You’ve clearly put some thought into that, bet you have a sketch and everything. Is it to scale?
I think a sketch or plan is a good idea. 20 vans turning up without any thought for how we are all going to fit is a recipe for disaster.You’ve clearly put some thought into that, bet you have a sketch and everything. Is it to scale?
