Can you get them that fit the 907 bottle
@Eli - Buy 1 of these from your favourite Warrington discount shop:
Campingaz Gas Hose & Regulator Kit | GO Outdoors
Standard kit for gas powered outdoor stoves, including a 29mbar regulator and 80mm hose.
And then buy a set of these, again from your favourite Warrington discount shop:
Continental Quick Release Coupling Nozzle (8mm x 8mm) | GO Outdoors
Make sure you put the female, not the male end of the QRC onto the valve end.
Put them together & it will fit your 907 gas bottle, as in the top blue assembly from the below photo.
If you want to make a QRC for a standard bottle of propane (connects with a LH thread) then just buy the right valve, as in the middle assembly.
This has the added benefit of a hand wheel, so you don't need a spanner to lefty tighty or righty loossey (LH thread remember!!)
The bottom hose is just an extension hose with a male QRC on 1 end & a female QRC on t'other end
Simples...
