Look for available WiFi networks, one called Venus pops up which is the inbuilt WiFi.Mine too.
I can’t do anything with it at the moment
I will try this tomorrowGo in the house and hit the WPA button on the router. This should allow you to connect easier. But you'll only have a few minutes until it goes back to normal
You've done well mate, it's worth persevering, when you get a minute. Then we can bully you into Ruuvi gear!I will try this tomorrow
I’m fed up farting about with it now![]()
See if it let's you scroll down a bit. Or ask a neighbour if you can have their password!
VM is mine too, I didn't need the wpa buttonI take it the VM is your house wifi. When you hit the WPA button this should allow an easier connection.
I’m going to have to spend more time on it tomorrowSee if it let's you scroll down a bit. Or ask a neighbour if you can have their password!
Wonder if Scottish Virgins are harder to connect with than English ones?Yeh it’s the top one
I keep getting this
When I press retry it instantly fails
OkBoth me and @Skyliner33 had this yesterday. Try shutting everything down. LB off. And let it settle down and then reboot it. Sorted mine straight away
Not in Dundee they’re not.Wonder if Scottish Virgins are harder to connect with than English ones?
I'm off tomorrow, all I have to do is wire up my new Ali Depress poptop lights into the Cerbo relays, I'm available!You'll crack it early doors and have a siesta for the rest of the day.
