Cerbo GX
No my 5g is off as it caused all sorts of issues as it is a stronger and faster signal than 2.4g but all my kit is on 2.4 and the 5g caused all sorts of issues with it so just disabled it and it cured 95% of the issues i was having
That's ok. That was just a screenshot I took off the laptop. Mine looks like your when I'm on van wifi. Scroll down and the 5g should be there. Just disable it and try your Cerbo again
No mention of 5g at all.
Ah. When i looked at my settings mine is a RUTX11 so has 5g. Apparently yours doesn't. So even more of a conundrum as to why the Cerbo is playing up. I had a similar issue when I tried to connect my Ring cam to the van and there was a setting I ahd to change on 2.4g. Hang on I'll check my emails
Ok that’s my Cerbo and everything else in and working and after reading all this I am now shitting myself thinking what have I got myself into? :oops: :rofl:
Where do I start setting it up?
Is there an app?
Found it. Change the 2.4g encryption to WPA2 only. That's what the Cerbo uses. Same as the ring cam. Not as secure but it worked for me
So I have just done the same firmware update on my router and everything locked out. Cerbo the lot!! Cured by guess what. Turning EVERYTHING off including the LB and letting it all restart. All working again. Feckin technology 😠
Found it. Change the 2.4g encryption to WPA2 only. That's what the Cerbo uses. Same as the ring cam. Not as secure but it worked for me.
Thanks.
That’s exactly what happened to me and how I got it working again.
