After all you went through with those vans. That is really sad, stuff the Cerbo, hope you are okay Chris.The van might be going up for sale![]()
I’m ok mate, thank you. Truth is I’ve got with a girl at a time where I was building the yellow van which at the time, was just for me. It became apparent we’d need a bigger van but truth is, we’re never going to use it. I have two dogs, she has two dogs so 4 dogs is just to much to either take away with us, OR put into boarding (two are old as well so it’s not fair on them). I think it’s just a case of bad timingAfter all you went through with those vans. That is really sad, stuff the Cerbo, hope you are okay Chris.
Every cloud and all that - vans are just 'things' at the end of the day, other stuff is more important, when it comes down to it.I’m ok mate, thank you. Truth is I’ve got with a girl at a time where I was building the yellow van which at the time, was just for me. It became apparent we’d need a bigger van but truth is, we’re never going to use it. I have two dogs, she has two dogs so 4 dogs is just to much to either take away with us, OR put into boarding (two are old as well so it’s not fair on them). I think it’s just a case of bad timing![]()
I feel complete now, Ruuvi number 3 attached, with a Mopeka to follow in due course!800w induction hob working away tonight cooking up some pasta, touch 50 is just so much easier to check on charge levels/watts going out etc!
Erm, did you get yourself a 4g router and a little sim card?After doing all the wiring and installation myself I’ve plugged everything in and switched it on and unbelievably it all seems to work.
But I’ve failed at setting the Cerbo up.
I can’t get the WiFi connected to it and therefore can’t set it up in VRM connect.
I go through everything and type in my house WiFi password and it just sits on the connecting page.
If I try again it just say connection failed.
I press retry and it immediately says failed.
Any ideas?
That's right up your street Gord, offer a tenner!If you go for a Tenda router. Don't buy one. There's one on a shelf in my garage looking for a home
Mines just bog standard Virgin, it worked straight away.Regards connecting to the house WIFI. Check what security it's set at. If it's above WPA2 then the Cerbo won't connect.
I’ve no idea if’s my house WiFi is WPA2Regards connecting to the house WIFI. Check what security it's set at. If it's above WPA2 then the Cerbo won't connect.
Mine too.Mines just bog standard Virgin, it worked straight away.
I’m trying to add my Cerbo in VRM app and it needs to be connected to WiFi to do this.You only need wifi if you want to tap in remotely via VRM. If that doesn't bother you Bluetooth with the app and just hotspot to your phone for updates
