Ian Rodger
Anyone with a modern Diesel engine use premium diesel in ur vehicle, yes it might cost a little more at the pump but trust me it's going to save you a huge amount in the long run.
Hang on a mo @PukkaT6......what about your discussion with the tanker driver? Anyhow, right now I'm in Perth....the Australian one btwAsda fuel all the way ha
I've not read all the thread, or in fact PukkaT6's conversation with a Tanker driver. How ever I can say in the group of people I ride with (motorcycles btw) is a tanker driver. He tells us if you but standard fuel (not the "super" stuff) all the tankers no matter what is marked on the station fill up from the same hoses at the refinery place. ie you get the same fuel at Shell/BP/Asda/Tesco and the fuel is best where there is a higher turnover so its fresher and the volatiles have not evaporated as much. This I have no proof of but I don't see why he would tell a load of porkies.
@PukkaT6 .....The petrol versus diesel bmw "debate"!![]()
Would heating oil work?All I use!.. some say it is too lean for vans but??.
Thread resurrection, sorry. My day job is aircraft engineer, helicopters as it happens.
Just thought I would add that diesel with water in it (and it all has some) will also cause big trouble in low temperatures when the fuel goes through a filter and the suspended water freezes blocking the filter.
This will bring you to an unwanted stop. Solutions are good fuel quality and regular maintenance fuel filter changes.
In helicopters we use fuel additives to stop the suspended water freezing in the winter. Always a good idea to keep the engine running.
Personally, I use supermarket diesel or whatever is about when I need it but try never to skip oil changes and regular maintenance oil changes etc.
I used to travel on helicopters a lot, I’m glad to say that the pilots followed your advice and kept the engines running.
Fuel has different additives according to region, we had big problems using Maltese fuel in Arctic Norway.
