The premium vs supermarket fuel debate will go on for ever, on every vehicle related forum, with around the same results as above.
All I know is I've run several diesels to super high mileage, including a 2006 Vivaro which were notorious for fuel related problems, and this did 300k without a single issue.
Maybe I am wasting my dosh, and maybe it is a placebo, but I get double points on all my reward cards, which pay for Christmas day, boxing day, and new years day dinner every year, and I get to feel I'm giving my vehicles the best they deserve for what I demand of them, and what they earn me. Plus I know anyone following my vehicles doesn't have to switch on the re-circ button because I stink of poor maintenance and crap fuel. Only flowers and freshly cut grass from my vehicle ass![]()
Um, forgive me but I don't think you actually mention which fuel you use. Can I assume premium?
I have a 2001 A4 1.9TDI with over 200K miles on the clock, it’s never had any engine issues from new and still goes as well as when new. It’s only been fed with the cheapest Diesel available.
A guy I know runs his old van on the cheapest cooking oil from Tescos but I’m not willing to go that far!
it's all EN590.........it also all comes from the same refineries.
Do you ever see HGVs running premium (genuine question)?
I'd rather use the money saved on bog standard fuel for an oil change every 10K/one year instead - your engine will probably appreciate that much more.
Then you know that whilst it all comes from the same refineries the additives are added at the terminal where it is loaded into the delivery tanker, that’s what makes the difference between a good fuel and a not so good fuel.
You dont see HGV’s using it but as fuel is roughly a third of their operating cost they are very price sensitive and they do have their fair share of fuel problems caused by bad fuel (those that buy bulk see much worse quality issues than we will see - such as B50 sold as EN590)
I agree about the extra oil drain though![]()
It's all good fuel - it all meets EN590 which is what your engine has been designed and calibrated to run on. I didn't realise they still had different additives though (except for the 'premium' range) or is that specific to your local refinery?
You have confirmed my expectations about HGVs not using premium. If the price of this fuel was offset by improved mpg and engine/fuel system maintenance they would most likely be running it; the downtime cost for a tractor unit is too high not to be running the most suitable fuel. These tractor units are putting on huge amounts of miles so if bog standard diesel works for them, it's good enough for our little vans too.
Biodiesel is a different subject though and given the choice of B5, B10, B15 etc you should always go for the one with the lowest number!
But before the additives are added it isn't EN590, its Diesel fuel to a lesser spec and EN590 isn't a fuel, its a specification with minimum and sometimes maximum limits for each specified area, an example would be the cetane number that has to be a minimum of 51 but your van would be much happier at 54 - 55.
It's a bit like saying a van is a van and they are all the same regardless of who makes them, as we know there are good vans and not so good vans with even the good ones being bad sometimes.
HGV Diesel engines are completely different matter as this is my specialist subject, with larger displacements they are much lower revving and spend a much larger percentage of their time at a very high duty cycle, the same rules do not really apply although they do to a certain extent as some of the benefits of Premium will be there although these wouldn't justify the extra cost.
As to bio, you should only go for what is approved for your engine and nothing else, interestingly EN590 is already a B7 fuel and has been for around 2 years now so you wont be able to get B5 for a road vehicle anymore.
Interestingly diesel fuel has a shelf life these days and is a also now classified as a flammable liquid, both a result of the introduction of Bio which basically partially turns to water & has lowered the flash point of Diesel below the flammable liquid trigger point. There are still tanks with WW2 fuel on some military bases and that fuel is still in good condition and very useable - modern diesel wouldn't be, even after 5 years.
What we should or shouldn't use in our vans isn't a debate really as we can put anything we want in our own vans, just don't complain if you buy cheap and then have problems.
I have a 2018 Caravelle Exc, and I use V Power as my commute is 9 miles a daySo - in yours you say you use ordinary fuel which I assume is standard diesel. Do you ever use premium?
I am asking as my new to me T6 Exec is 8 months old with nearly 9k on the clock and was used by Bentley, I assume to ferry prospective customers around. I just want to make sure everything is in perfect condition and ensue the DPF is clear after a few fast runs I have planned on motorways here and in France next month.
Do you consider premium fuel is worth the extra cost for 8-10k per annum
