Thank you very much! Now the map structure (the "E"'s) is starting to more sense to me.Same for Turkey btw. Look this is the bundle you pasted (bundle 1). But missing Turkey and Russia. This is error on website, but correct in Discovery SW.
Btw Russia itself is almost 9GB![]()
Sorry I think perhaps I was not clear, the new map will not fit on the supplied VW SD card as it is 16gig but the map folder is almost 17gig. So you have to either load a smaller map, play about deleting, substituting files on the standard map or get a bigger SD card.Is it not easier and cheaper to patch DM yourself for any SD card use?
Of course you can throw whatever map you like on whatever 32GB SD card once you do the patching of your DM.Sorry I think perhaps I was not clear, the new map will not fit on the supplied VW SD card as it is 16gig but the map folder is almost 17gig. So you have to either load a smaller map, play about deleting, substituting files on the standard map or get a bigger SD card.
you can not just copy and paste to a bigger card as it does not work (unless it’s a VW card or CID adjusted as above - wheew - hope you folloW.
Hi Robert, to be honest the thought of going into the DM operating system and tinkering with the settings using downloaded external software which you then install into the head unit just fills me with dread.Of course you can throw whatever map you like on whatever 32GB SD card once you do the patching of your DM.
For your information the CID card arrived from an EBay seller is 32gig and it works perfectly. Wahoooo!!Anyway I have given it a go and purchased a blank 32gig SD card with CID for £18.00 delivered, let’s see if it works
Do you have a link to that please?For your information the CID card arrived from an EBay seller is 32gig and it works perfectly. Wahoooo!!
It was this item number 254365746184 Note - you have to contact the seller to instruct him to do for VW. I found him very quick and helpful.Do you have a link to that please?
In brief you can not use just any SD card. It has to be a VW card or a card which has been made suitable by setting the CID information which is embedded in the card (scroll up to earlier post).Hi I'm new to the forum but I've followed the thread as I'm trying to get my Nav system to work.
I have just got a 2019 Amaroc. It has a Discover Media system with 2 SD slots on the front. It came from the Eastern side of Australia (Sydney) and is now in the west in Perth. It came with out its Navigation SD card ………
I’ve followed VW’s DiscoverCare navigation update instructions to put maps on an SD card. It didn’t not, I’ve read this very informative thread and others to try and get my system to work. But no luck. So I’m wondering if anyone can help.. Here’s an overview of what I’ve done so far.
I have downloaded the latest maps - World bundle 3 - Updated: 2021/06/21 to an SD card
The download folder on my windows PC is titled
DiscoverCare_v.1.0.4_win
The title of the maps I have put on the SD card according to the DiscoverCare app is shown as
5NA.919.866.BN 1710 MRM3 2022
When I open the SD card (does it need to have a specific title?) the following folder is shown
maps
inside this maps folder are the following folders (don’t know which number is the Australian maps)
22
23
26
27
EEC
When I insert the SD card into my system I get the usual
Navigation database not available
I have done a reboot to my system by holding the left hand on/off knob for 5 seconds plus.
I still get the same.
By holding down the MENU button, the screen shows the following
Installed SW version MST2_EU_VW_PQ_P0475T
Installed SWMU version 0475
Software version H29.319.76_STD2NavPQ_EU
Current version MST2-EU_VW_PQ_PO475T (0475-1)
When I now try using the update button, and selecting the from SD card option. The following error message comes up
Unable to read the Release Information file.
No release available.
Can’t find update container.
Any suggestions on what to try next?
Thanks in anticipation Martin
Or tell us the seller please @Nigel WI suppose as always they are after your money................ I forgot to ask you Nigel - I can't find your EBay item number 254365746184 for the VW CID coded SD card. Can you possibly post another link?
