Referring to VAG DPF app? Last time I used Group 15 - CXHA(2) as it seems to be a bit more relevant than the other two. The other groups show some parameters not meaningful in T6 engines.As stated previously, the 204HP works, but gives different values when selecting between CXFA and CXHA(1) and CHXA(2). Which is most correct for the CXEB engine?
Agreed that the percentage value doesn't work very well. It seems to be just a somehow calculated value from calculated soot mass and regeneration trigger level.Yes, sorry, forgot to mention the app.
They all give various values of how much % is left to renegerate. Mine stopped reneg at about 35% today.
Nope been checked, its fine, the vibration is also coming from exactly where the DPF is and its a bit of a coincidence that the vibration noise is gone when a regen is happening... It's annoying the crap out of me now, no one can find the issue, every mechanic thats looked has said definitely not DMF and sounds like its coming from the airfilter housing but unable to find where, not far below that is the DPF. When i first got the van i had to have the flexi on the exhaust replaced as it was making a noise. That solved that issue but not the vibrationDMF surely?
This could be to do with the fit of the exhaust system (cat through to last silencer hanger) and heat. During the regen the DPF is getting up to some serious temperatures so that the trapped soot and be converted into ash so a noticeable amount of expansion happens to the exhaust system. Once the regen has completed the exhaust system will then slowly cool down to the normal running temperature (perhaps why this vibration comes back five minutes later). It's interesting that the flex pipe has already been replaced as that is often a sign that something in the exhaust system is out of alignment or is moving excessively in a twisting/rotational sense.
Can I have more info millage and year? And what sort of miles you do?
