nazarko1984
Thank you Guys ones again for support.
@mmi According to pressure on DPF, do I correctly understand if there is low pressure different, then DPF is working like a "stright pipe"?
What I notice during burning DPF, the RPM's growth up to 1000 but fuel consumption is still at the same level. In my previous Van (F. Galaxy) when DPF start burnout process, fuel consumptions always rised for about 0.5l more.
Tomorrow I will read the logs again and will start DPF burnout from VCDS.
Action taken by service - fault finding. No more info about it.
This has place 20kkm ago.
I will try to contact previous owner, maybe he know something more and didn't told me before.
Here you have requested pictures and one video with CAT.
During recording this video I have notice some oli leak near CAT on 2 plastic pipes. Not sure where they are connected.
I have check service history and indeed previous owner report to the VW service some issue with DPF. The report was -" the glow plug indicator light is on, the car has lost power, the DPF indicator light is on, DPF filter is suspected to be clogged."Well, at some point DPF ash accumulation value has been adapted.
4.33 grams suggests the value was set to zero approx. 12.000 km ago (7.500 miles).
Mine has 28.2 grams at 80.000 km.
Is it possible the DPF has been replaced with a non-genuine DPF? The OEM DPF should last approx. 300.000 km though.
