Be careful with this module I bought one from that specific seller it was not working. Same did a another guy in Turkey same module, does not work. I bet you will have a hole under your label at the TRW location where they have drilled in and modified the EEPROM. FYI so you should test you can talk to it with VCDS before putting it into the carAnother perfect match.
Re-pining also completed.
Just need to extend 9 "control" and 8 "power" wires.
