EPB Retrofit ... the way to Stop & Go
Here is a list of possible calipers, not validated, probably best added in my first Post.
From Audi A4 (8W2, B9)
8W0 615 403 A (BHT723E) BHT723E - TRW Automotive Aftermarket-Teile
8W0 615 404 A (BHT724E)
or From AUDI A6 (4G2, 4GC, C7)
4G0 615 403 A (BHT327E)
4G0 615 404 A (BHT328E)
or From AUDI SQ5 Q5 Typ 8R (200:cool:
8R0 615 403
8R0 615 404
Are we close to having a costed up solution offered for non-DIYers? It would be ace to lose the manual handbrake and chuck a fridge in there instead!
Another amazing functionality of EPB - conditional Auto Release.
This feature is fully configurable and
I have chosen to auto release only if driver's seat belt is fastened and door is closed.
Also video demonstrates my "temporary" location of my EPB switch unit.
I have gained on clearance space between front seats
after removing mechanical PB and associated trims so I am happy as it is for now.
But some day when I discover ideal location in the central console/dash I will move it there.
@dnoermann I can't express how grateful I am for your idea.
Thanks a million, @dnoermann is the man!
after removing mechanical PB and associated trims so I am happy as it is now.
Dennis is your car doing this?
VW CC CCTA ACC with Follow-to-Stop (FTS) - YouTube
PQ35 gets AUTOHOLD by default after connecting 56D EPB(subject to ABS type). PQ25 is not that simple but achievable :thumbsup:.
Reactions: mmi
I now have
4G0 615 403 A and 4G0 615 404 A
from AUDI A6 (4G2, 4GC, C7) for 330x22 Disks.
I finally found time to install the Calipers Last week.
It is Really Plug and Play.
Everything fits perfekt, only one little adaptation is to be made: The Holder for the brake lining wear indicator Connector needs a new position.
First Function Test passed and First drive Test passed, too.
Still no Stop&Go functionality
But Auto-Disengage is a very cool Feature.
Todo:
- Get Auto-Close implemented
- Get Stop&Go implemented
Just to weaken your expectations.
I have a T5.2 (2013) which eletronically got upgraded to a T6. But i still have the EU5 CFCA Diesel Engine, with retrofitted ACC support and DSG.
Following is working.
- EPB Manual Close/Open with Switch
- With closed EPB car is not moving with DSG in D/S or R <== change to before
- With closed EPB car is not moving with DSG in D/S or R when pressing Accelerator pedal EPB auto opens and Car moves <== cool feature
- Doing FTS with ACC the car is approx 1 Second longer hydraulic Breaked than without EPB (exactly like in my first Post)
Following is not working.
- AutoClose of EPB
- ACC Stop&Go like in Sharan
No Errors and all Features work like Expected.
BUT @Robert now must Post the Problems in his T6 with EU6 Engine.
We are right now not shure why it is behaving differently ....
Still comparing differences ... Hopefully it is not an issue of ECU ...
Hi Robert, can you post some guidance on Brake Caliber procedures and coding.
I have these 2
Wednesday,21,April,2021,16:05:04:05193
VCDS Version: Release 21.3.0 (x64) Running on Windows 8 x64
www.Ross-Tech.com
Address 53: Parking Brake Labels: 56D-907-801.CLB
Control Module Part Number: 56D 907 801 B HW: 56D 907 801 B
Component and/or Version: EPB-4 H04 0005
Software Coding: 0F3C55
Work Shop Code: WSC 00078 790 00179
ASAM Dataset: EV_ParkiBrakeTRWVW411 002007 (VW36)
ROD: EV_ParkiBrakeTRWVW411.rod
VCID: AA06E8D07DFEEDCB717-80FE
2 Faults Found:
853248 - Control Module
C109F 00 [137] - Incorrect Version Installed
[FC_WRONG_CARTYPE]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 68
Mileage: 93420 km
Date: 2020.14.11
Time: 15:51:48
Voltage terminal 30: 12.3 V
Internal Fault ID: 126
Vehicle speed: 0 km/h
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: applied
Status ParkingBrake right: applied
197632 - Function lamp in instrument cluster
C10FF 15 [137] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 93420 km
Date: 2020.14.11
Time: 15:51:48
Internal Fault ID: 160
RWU: not active
DSD: not active
HTR: not active
ECD: not active
