853248 - Control Module
C109F 00 [137] - Incorrect Version Installed
[FC_WRONG_CARTYPE]
You need to change the last adaptation channel and effectively disable VIN check.
To do this you need to use very secret SECURITY CODE, which our kind friend @dnoermann has put publicly already.
197632 - Function lamp in instrument cluster
C10FF 15 [137] - Open or Short to Plus
For your warning light you have a choice of two options.
1. Modify IC electronics to allow "positive" signal to be taken instead of "negative" as a parking brake applied confirmation.
Eeprom editing is also required and it needs to be switched there from manual version to electronic.
2. Use Solid State Relay with very low current consumption on its control side, see below.
www.t6forum.com
[FC_WRONG_CARTYPE]
EPB Retrofit ... the way to Stop & Go
Ladies and gentlemen, let me present you my (world's first?) VW Transporter/Multivan/Caravelle T6 with Electronic Parking Brake :D I just need to complete the wiring of my PARKING BRAKE indicator in INSTRUMENT CLUSTER and AUTO HOLD. The skills of people on this forum never fail to amaze me...
