Fitting the rails isn’t that difficult. Just need the correct tools and a bit of patience. There is a good thread on here that explains it all.thanks deaky, the wife is sold after those pics - just need to see the swiss pricesotherwise im going to have to get kernow to deliver to someone in the uk then get the rails sent over and then do it myself..
the floor i must admit worries me![]()
Oops you’re correct.Ok got tools and the patience..! Link to thread? I thought it was this one?!
Oh, I remember that bolt nowI agree with @Skyliner33 - I fitted my SWB Cali rails based on what I had read here.
The indentations in the floor indicated where the rails should mount, and I used the old (two-piece) ply floor as a template for the new one-piece.
The OEM Shuttle/ PV / Kombi mat coupled with 12mm ply makes for a suitable height to lay your carpet / vinyl.
The only grief I had was tightening up one of the bolts where it fell close to the rear nearside suspension - I couldn’t get the torque wrench in there (and couldn’t be arsed to dismantle the suspension components) so I tightened it up best I could and then got it torqued-up when I had the van in the garage next.
I've thought about this and im keen - but with covid etc im not sure we can come into the country without 14 days afterwards.. im also not sure that our version of dvla would accept a uk work..even vw certified.. its a bit of a headache!hi mate would it not be cheaper to drive to uk and have work done over here and a holiday/break to boot![]()
hi, yeah the kombi bench i have, its fixed.. i was just wondering if all the sliding benches were the same - ie cali caravelle and multivan?Hi @scotia ,as far as im aware,all Caravelle seats fold flat into a bed and yes,they are designed to match up height wise with the multiflex board. I think the other 3 seater benches that youve seen are probably Kombi benches which wouldnt fit into your floor rails,if any of this is wrong,im sure someone else will correct it,hope this helps and good luck
it'd be the beach that has the 3 seater as there is no kitcken in a beach. ocean and coast there are.. ok thanksI think the cali ones are just a two seater except maybe the Ocean one? Cant comment on the Multivan because i dont think we get those here but i think all the Caravelle ones are the same just different materials
