Hi Kasha, I noticed your from New York. I have never seen a T4, T5 or T6 Transporter in North America, have you got one?Excellent posts. Thanks for your honest efforts.
I might have a spare one if your interested?Could anyone that have the vents in the B pillar please measure how far up the trim the grills are please. Some have the moulding marks on-site as a cutting guide but unfortunately mine hasn’t.
B-Pillar Vent
I have to admit, this was the more scary of the cuts to make. I removed the drivers seat to give me a bit more room; if you can I’d also recommend removing the seat base - i couldn’t due to all of my leisure electric bits.
I also removed the seatbelt top and bottom mounts as well as the inertia reel. It just gives more room and makes sure you don’t snag it when cutting.
In order to figure out where the vent piece goes I used some putty to stick it to the metal work, then installed the b-piller trim over the top, and fished through the holes in order to line it up. Removed the trim, drew round the base of the duct.
(Please ignore the spray glue deposits I had to rip off the carpet trimming to do this job)
Start cutting. Again I used a holesaw to cut out the corners, then a multi tool with metal blade, and a file.
Once all cut and shaped, poke the main duct up through the bottom of the van.
Pop some paint on the cut edges.
Screw the top frame guide piece on, then clip on the b-pillar vent guide.
My top tip is to remember to refit the seatbelt inertia reel before you put this vent guide on, because otherwise, like me, you’ll have to take it back off to get to the bolt.
Hi Dave
Excellent install... I Have a question how did you mark out the B pillar hole to make sure it was in the right place for the top part and then making sure that meets up with the B pillar vents once there fitted?
Shaun
I'm about to do this as well.
It's a shame there isn't a pattern we could use to mark out the holes needed.
I'm thinking of drilling a reasonably large hole somewhere near the middle then gradually cut the hole larger until it fits.
I haven’t seen or heard of an OEM part for this; it’s not on the parts pictures that i’ve got.Need a bit of help guys. I previously saw a photo of the inside of a T6 (think it was a proper VW photo as opposed to someone here) and it showed an additional duct that ran from the oem hot air outlet and up to the bed area of the pop top to divert the hot air up there. It was removeable too. Anyone know where I could buy such a thing?
First proper night in the van since I fitted my propex and I’m freezing all night in the pop top bed and my wife and kids are too hot below in the rock and roll bed. I thought the hot air would have rose to the pop top but it seems it isn’t doing it enough. Wondering now if I could rig something up at night to divert more heat to me than them
