They said they need to charge it for 12 hours and then monitor it?
Just booked mine in for next week with the same issue. I was told the same thing, needs to be in for at least a full day, most likely overnight. V annoying
Strangely the auto stop/start now seems to be working. I assume that’s because the battery is now charged fully. For the last few weeks the stop/start has barely kicked in, I assumed because of the colder weather and I’d been mainly doing short trips in the van so rarely got up to full temp. But went on school run an hour ago and the stop/start was kicking in even though the engine wasn’t up to temp (I’d only driven about a mile). This is by far the most inconsistent vehicle I’ve ever owned or driven.
Thanks, I will look tomorrow.Do you have a Moll battery?
There is a known issue with them and the dealership should replace them without hassle.
2017 150 Highline man. Definitely not a loose cable, but your suggestions match my Dad’s, who also suggested a sticking bendix in the starter motor.Dodgy starter motor?
Loose battery cable?
Defective starter battery?
You didn't say what van and how old?
This is the first time that the engine failed to start, but on a few occasions it has sounded reluctant, usually first thing in the morning when cold and is not weather specific.very good, lol, credit to your dad then.... thats old-skool mechanics line of thought.
we might need a bit more data.
how often does it happen,?
Cold or hot?
wet or dry?
before a drive or after a drive?
though either way on a 2017 you are well within warranty and that will store a fault code for a "failed start", for VW assist callout or booking it in yourself.
thinking back . . . . . . . i think the ECM stores a code saying that its fired the starter motor but failed to get a valid rpm signal from the engine (failed start) (i had a loose starter BAT+ cable on my old T5.1 and had the same symptoms and remember the fault being logged)(VW blew up the engine so it was in/out and a few cables and fixings were missed which had caused the loose starter cable)
The ECM fires the starter motor signal for ages until it registers the cam or crank rpm signal then disengages the starter supply.
have you got Carista or VCDS to do a code scan?
Carista . . . . . .
Carista - How I Done It -
Dellmassive`s -- "how I Done It" -- Thread
Thank you.Cool. Ask them for the code read out. Slow starts will not be logged.
But total no starts will be..
Might just be a lazy battery so ask them to test the battery.
You could get a second opinion from Halfords. They do a free battery drop test Apparently.
Same thing happened to my van. Faulty battery. If your battery is the MOLL type, VW will replace it with a better battery for free. Well, they did mine anyway.... As above, MOLL batteries are a VW known problem and are replaced under warranty.
I wish! VW have to go through the protocol. I had to get recovered, AA guy said the battery was dead and needed replacing no question. It was so low I couldn't lock my tailgate. VW charged it for 12hrs, re-tested and stated that the battery was fine. The battery is 1yr old in a van with 15k miles. No doubt its going to happen again.
Thanks, but I have been in to heritage and asked about recalls, none for my reg. My van is covered under warranty & I refused to collect it until the battery was changed. They would not change it, after 5 days I had to collect. I can already feel that it will happen again shortlyThere's a VW recall code online. I will find it again for you. VW don't tell customers these things. But if you go onto the VW Van Centre service site online you will find all the recall notices....
Took it to Heritage Bristol who did the heater repair, and I cannot fault their customer service.Thanks, but I have been in to heritage and asked about recalls, none for my reg. My van is covered under warranty & I refused to collect it until the battery was changed. They would not change it, after 5 days I had to collect. I can already feel that it will happen again shortly
