Does anyone have knowledge of the relay adaptor that @travelvolts used to supply which was used to allow a dc-dc charger to be connected to the factory second battery wiring?
@Dellmassive?
My issue is this:-
My ctek 250se is not charging my Renogy LiFePo battery.
All the lights on the ctek behave as though it’s working perfectly. I start the engine I get the green and the two bottom yellows to show it’s charging from the alternator. I also get the top orange to show it’s charging from solar. Without the engine in I get the green light and the two diagonal orange to show its charging from solar.
No flashing fault lights etc.
However-it is not charging the LB.
All fuses are good. All wiring looks ok.
I’m in Spain touring around.
Is it possible to just remove the wire from the battery output of the ctek that at the moment goes into the travel bolts relay and replace it with a normal fuses 75a lead direct to the battery this elimination that as a possible problem.
Also, if the internal fuse in the ctek had failed would the ctek still be showing all the correct lights or would it flash an error does anyone know?
@Dellmassive?
My issue is this:-
