I can't seem to send you a PM, the forum won't let me. Have you got an email address I can use to send you details? I don't know why I can't PM you.Awesome @ChrisR looking forward to it.
nothing in there from you, if you would rather not share your email on the forum, send an email to me [email protected] and I'll reply to that.Hmm I wonder why that’s why I have not received replies to my PM’s.
Check your PM.
got it, thanks.PM just sent.
It's been a couple of weeks since I fitted my suspension, so took it in to Bognor Motors for a health check and alignment. Well it was a good job I did!
Did I mention what a pita the rears were to get level and sort out on my own in my garage swapping from one side to the other? Well, it turns out I have not aligned the lower rubbers quite right, so they are likely shot now. They didn't have any more in stock. so booked back in for a week Tuesday.
They were also not happy with my solution with the front brake hoses and wear sensors as they need swapping around cos the kit is designed for the T30 and below rather than the T32.
I could have taken it to someone more local who would just have aligned it and sent me on my way non-the-wiser.
But this is why I take it to someone who knows what they are doing better than I do.
Well worth the trip today, even if it's not resolved yet.
The ride is still superb though. After modding the inner arch I've not had anymore scuffs and not raised it.
I'll take a proper side on photo once the issues I created are resolved....![]()
Lol. You’ll see me again.I'm glad we were been of help, where do we send our invoice ;-)
It will 100% drive better, when properly aligned on Hunter, its not your imagination
Enjoy
How low is it set there is that at the maximum 80mm ?Unfortunately I had a bit of a trip at the weekend before BM could fit me back in, so back into the garage and rear rubbers changed.
Then got it ‘Huntered’ locally. Didn’t want to do any unnecessary tyre scrubbing.
My perception is that it drives better, but not sure if that’s real or just convincing myself...
Anyway, all done and running sweet
Please can you explain the wheel arch mod you mentioned. ThanksLol. You’ll see me again.
No. About 65mmHow low is it set there is that at the maximum 80mm ?
At about 12 o’clock inside the front wheel are is a retaking screw. Remove it and push the inner arch up over the tab. Gives a bit more clearance.Please can you explain the wheel arch mod you mentioned. Thanks
... and then you can push the tab up gently to get it out of the way.At about 12 o’clock inside the front wheel are is a retaking screw. Remove it and push the inner arch up over the tab. Gives a bit more clearance.
