Many thanks pal. I already have CC on the stalk but the steering wheel arriving tomorrow has it so hoping to use instead of stalks.For a mfsw only you need 2 wires 3 is needed if your adding cruise on the wheel
No need to order if you already have cruise just fit and re pin.Many thanks pal. I already have CC on the stalk but the steering wheel arriving tomorrow has it so hoping to use instead of stalks.
I’ll have to buy two packs then so that I can get the third wire
Anyone selling a pack of three by any chance? View attachment 179186
You are a star!No need to order if you already have cruise just fit and re pin.
Move one of the black/yellow wires from pin 26 (or 29, as they are connected) to pin 11. This is the cruise signal.
Move the black/blue or black/grey
wire from pin 28 to pin 9. This supplies +12v.
Move blue wire from pin 31 to pin 10. The other end, in the white T73b connector of BCM will need moving from pin 46 to the pin 36.
Remove the black and yellow CCS wire from pin 45 on the BCM connector T73b.
Then check coding.
ECU 01:
Set Byte 05, Bit 5 Tells the ECU CCS is fitted
BCM 09:
Set Byte 09, Bit 3 Tells BCM a MFSW is installed
Set Byte 15, Bit 0 Only for a wireless that can use push to talk for mobile phones
Set Byte 17, Bit 2
Set Byte 17, Bit 7 Tells BCM CCS is installed
Set Byte 29, Bit 6 Tells the BCM to use pin 36 on T73b for MFSW LIN Bus
Call me if you want
That’s handy! No repair wires! Got itNo wores needed IF you have existing cruise control stalks. But if your insistent in leaving the original stalks in play make sure you disconnect the appropriate wiring so they no longer work
Hi pal! I managed to find another one prior to seeing this message but if that falls short I will come back to you. Cheers palI can get you a new harness but direct from VW it won't be cheap
Hi matey, what what I can see that only has 3 wires and not 5 on the black plug which I thought was needed for MFSW with cruise controlI think this harness will do it looks like the one I used … . eBay have these
