[Guide] Solar Cables? . . . - How I Did It -
Any chassis ground will do.
There is a ground stud by the rear wheel arch. Also in the D pillar.
Or make a new ground by drilling into the body with a self driller or nut-bolt-nut.
Edit: post never got sent properly. Resent.
@czmate1999
looks good. . .
though i wouldn't trust those blue crimpers for the 50A Anderson connectors.
you need a good proper crimper for those . . . . . . . .
i like the HS-16 . . . ( you can use them on the red,blue,yellow crimps too . . but not for MC4 )
Here are my HS-16 crimps on andersons . .
i would also look at getting some heat shrink for the cable ends at the Andersons can have a large opening where the cable goes in. ( possible short circuit risk by coming into contact with other cables, connections or devices )
its good practice to insulate the cable / connection as shown above.
Just looking at the chassis ground on the above set up. Is this going to be required for adding solar to an already installed set up which I would presume already has a chassis ground?
