Actually I'm not exactly sure what T91 and T91R are referring to. Sellers seem to use them a bit vaguely.Thanks again - and hopefully my final dumb question! I am trying to purchase this kit:
The seller is asking if I definitely need the T91R and not T91.
I have an early 2016 T6 Caravelle with Thermo Top Evo (Euro 6 engine) -would the linked kit work with my webasto or do I need the non R version? Thanks again, James
Coding 4101 - Does the Webasto now turn on - when engine is running and A/C system OFF ???coding 4101 Engine running - A/C system ON - WebastoON
Coding 4101 Engine running - A/C system OFF - WebastoOFFCoding 4101 - Does the Webasto now turn on - when engine is running and A/C system OFF ???
Hmmm... running out of ideas... only thing left is to check how the measurement values are when Webasto is running.Coding 4101 Engine running - A/C system OFF - WebastoOFF
C
If still no success perhaps you could record all measurement values again Engine running - A/C system ON -> so that Webasto is running (after 3 minutes).
Perhaps you could do it then manually - all the measuring values - tick 12 values at a time, Save, tick next 12 values, Save,.... there are total of 165 of them.
Engine running - A/C system ON -> so that Webasto is running (after 3 minutes).Hmmm... running out of ideas... only thing left is to check how the measurement values are when Webasto is running.
Thank you very much. I think I have learned quite a bit of how Webasto aux.heater is integrated into T6.Engine running - A/C system ON -> so that Webasto is running (after 3 minutes).
You are correct with your answered questionsSo I managed to get my firmware updated via VCP yesterday thanks to using the VCP user map. Nice friendly guy who was very helpful and all sorted quickly with no problems!
I dont have the kit to connect up yet - waiting for it to arrive from Poland. But just posting up what OBDEleven is now showing and a couple more questions for connecting up!
Firstly the fault code - I assume this is the code from not having a controller connected?
Secondly - for connecting up the telestart. Is it literally a case of positive to the fuse holder and put in appropriate (5amp?) Fuse? Negative to earth point below and signal wire to red connector with green wire? How is it wired to the green wire? Do I need a connector type or do I solder into the wire itself?
Thanks again guys
The fault is because of missing overhead control panel - nothing to worry about.Firstly the fault code - I assume this is the code from not having a controller connected?
Basically yes - just the power. Signal wire should be green/white (connector T17p pin 1) as here:Secondly - for connecting up the telestart. Is it literally a case of positive to the fuse holder and put in appropriate (5amp?) Fuse? Negative to earth point below and signal wire to red connector with green wire? How is it wired to the green wire? Do I need a connector type or do I solder into the wire itself?
You should have a pair connectors - where green/white is only on the one from Webasto.Perfect thank you - will fit with 7.5a fuse.
Thanks for wiring info - I'm more after the mechanics of how best to fit it to the adapter without cutting into the green/white wire in the block? Or is that the best way? Will be fitting this next weekend when the kit has turned up
Hi. How you found that you have remote module? I need to check in my T6 because its no remote on webasto, and I have to add.This is a really interesting post. I am working on a friends van at the moment. It's come all the way from northern Norway to Scotland to be converted from a panel van to a family shuttle.
It has a Webasto coolant heater, factory installed, with remote module but NO REMOTES! I have ordered a new remote but will need to code it once it arrives. I've done a VCDS scan and noticed there is no label file for the aux heater. I haven't seen this before.
Do I need a label file before I can interrogate the module properly to code this remote or am I missing something obvious?
I have posted a request on the VCDS forum for some help but I noticed @mmi seems to be the resident expert in this section
VW Transporter 2012 - Webasto Aux heater remote coding (label file none)
Any help or guidance gratefully received.
Craig.
Hmmm... not sure about that. Please post full VCDS Auto-Scanin VCDS say that remote installed...
