Hi,
I'm back in this topic.
MMI, maybe you could help me.
On my engine (Caravelle T6 2016 - 150hp TDI), I already have the DEFA warming system (the 220v heater screwed on the bottom of the engine).
This is "just" warming the bottom of the engine/oil.
I would like to install the DEFA 413708 (220v, it's warming the cooling liquid, going in the engine - I have this on a Honda here in Lapland, the engine is warm...).
Like that the engine and the cooling liquid are already warm.
About this part, on some shop I can read :
"Huom! Moottorin ohjainlaite on päivitettävä uudelleen kun moottorinlämmitin asennetaan autoon, muuta asetus: VW Codification Block 5 from <<43>> to <>taiVW Codification Block 5 from <<63>> to <>Riippuen siitä onko "Block 5" alkuperäinen asetus "43" vai "63"."
In english :
"Note! The engine control unit must be updated again when the engine heater is installed in the car, change the setting: VW Codification Block 5 from <<43>> to < > or VW Codification Block 5 from <<63>> to < > Depending on whether "Block 5" is the original setting " 43" or "63"."
m.motonet.fi
But few years ago I already changed the settings for the Webasto (first page of this topic).
MMI, do you understand if I can keep the webasto set like currently (warming the cabin + the engine), and the DEFA 413708 ? (Of course, I will not start the webasto if the car is on the 220v).
In english :
Defa-letkulämmitin #413708 | Motonet Oy
Huom! Moottorin ohjainlaite on päivitettävä uudelleen kun moottorinlämmitin asennetaan autoon, muuta asetus: VW Codification Block 5 from to tai VW Codification Block 5 from to Riippuen siitä onko Block 5 alkuperäinen asetus 43 vai 63.
