Thanks for that. Do you have the link to these? I can't see them, just vast numbers of replacement bulbs!There are a pair of H7's on ebay, came on today £75 incl postage, slight damage to drivers side.
Great! Many thanks.![]()
VW T6 OEM Headlights | eBay
<p dir="ltr" style="margin-top:0; margin-bottom:0;">VW T6 Headlights.</p> <p dir="ltr" style="margin-top:0; margin-bottom:0;">Used but like new condition. </p> <p dir="ltr" style="margin-top:0; margin-bottom:0;">Passenger side light is the headlight with minor flaws through storage. (one photo...www.ebay.co.uk
Hi,It was just the bulb warning light on I couldnt find anything on Carista to sort the bulb fault so left it for now,I have read it can easily be sorted with VCDSThanks for your reply and link - nice to see Deutsche Parts still have them in stock.
Could you explain further about 'the bulb fault with the LED DRLs'?
Is that something which could be ironed out by Carista/VCDS? My current DRLs are the basic non-LED type, which it would be nice (but not essential) to upgrade.
Hi Ian thanks for that just read you earlier post on this. where did you buy the replacement bulb holders from as I actually managed to bend one of the contacts whilst fitting the LED bulb so would be nice to change it as it looks a bit weak nowHe means the earlier H7 lights had a problem with the DRL - the click in connectors of the bulb holder can overheat due to a resistive connection. The later ones were modified as a wired bulb holder. You can also buy a replacement wired bulb holder to fit the older units (snip a couple of cables and solder in) which is what I did for peace of mind rather than them being melted!
Hope that clarifies.
Ian
I’ve got H7 lights on mine and they are entirely adequate, I’ve never thought they need to be better. Admittedly not as good in comparison to HID or LED lights but as a set of halogen lights the H7 units are good.Interesting! That puts a different complexion on it. Any thoughts?
Stu,Hi Ian thanks for that just read you earlier post on this. where did you buy the replacement bulb holders from as I actually managed to bend one of the contacts whilst fitting the LED bulb so would be nice to change it as it looks a bit weak now
Cheers @Paynewright just cost me £24 from cov vw van centre round the corner,like you say pricey even the bloke on the counter was surprised at the cost.But soldered on now and repaired . much happier as the contact I bent actually fell apart as I pulled the bulb out the original fittingStu,
They are a VW part called a ‘Repair Kit’ 7E0 998 953. Bit pricey for a design error at £20 each !
I work on Bayton Road 5 mins away!!Thats the van centre I use. I’m over near Lutterworth.
That sounds very sage advice, if (as it seems), those with H7 conversions deem them satisfactory in practice.As you have seen yourself, the H4s appear almost dangerous to most of us who have used them.
You may be overthinking it. A couple of hundred quid will get you uprated H7s which aren't fantastic, but are decent.
Aftermarket will be twice that.
Anyway, you pays your money and you makes your choice!!
Patience oh benighted oneThat sounds very sage advice, if (as it seems), those with H7 conversions deem them satisfactory in practice.
I therefore decided to follow that line, if possible. However, so far, it hasn't proved easy.
E-Bay, as suggested by many, has a wealth of spare headlight assemblies, but very few adverts state that they are H7s - or mention bulbs at all.
One, which seemed promising, turned out oin enquiry to be H4s; another seller hasn't responded to my email - so I take it his are H4s, too. Stands to reason that everyone seeking to upgrade from standard will also be wanting to offload their useless H4s. There are unlikely to be so many Caravelle owners wanting to upgrade from H7, because they are a better light, so there's less incentive, and there are also far fewer Caravelles around.
I therefore decided to try the Eurowagens, which are advertised on E-Bay at £229.90. The advert states these aren't OEM, but are brand-new and it claims they contain H7 bulbs. I checked the compatability chart provided, and this says they are NOT compatible with my van. I can't see any reason why they shouldn't be - but their lights are not OEM, so maybe there is some underlying difference?
I therefore entered into email correspondence with Eurowagens, supplying my VIN number no less than three times. Their eventual conclusion - my van uses H4 lights (I know that!!), and they don't stock H4s - I would need advice from an Automotive Engineer about compatability.
They say: ' ... converting your headlights... this is not a quick or simple change. These may fit into your vehicle but the power, plugs and wiring would be different, these would all need to be changed to accommodate the headlights you would like to install. We understand that H4 bulbs are not the best, and there is no form of upgrade which we have that would be a plug and play replacement for your current headlights. We would advise to speak with the specialist and have a look online to see what others have done to change the headlights'.
So, it appears that the search for second-hand H7s must continue, unless I take the easy (but expensive) way out and buy the THQ V3's, with the additional choice then to be made of whether to have really good lamps (but technically illegal/unlawful), or lesser ones which to some extent negate the point of spending so much on lighting.
I do wish VW hadn't been so cynical and disregarding of customer safety in their original lighting specification. But that's the nature of the beast.
