The new mini LED headlights are the worst. Serious eye burners
I went from H4 to H7 with Osram Nightbreakers and fitted Foglights ( clear glass) at the same time with 55 watts nightbreakers. Very pleased with the results (please see pictures with and without the fog lights) a dramatic difference compared to the upgraded Philips H4 light.
Hi huib berger, When you say that you changed from H4 to H7 did you change the headlamps as the two bulbs have got different fitting caps
The 2nd picture is def a lot better and we could live with that
Yes thanks for that I will try and see if I can find a site that sells them on the continent and do it that way ThanksYes, I changed the headlight units (RHD second hand ones are widely available on the continent and not too expensive).
On the two picture you see that the dipped and main lamps together provide a good light pattern from close by to reasonably far away. The 2 photos are both taken with H7 and the difference is the fog lights on or off
These fog lights are provided with Osram nightbreaker bulbs in (with the appropriate fitting of course).
Sorry for causing the confusion, you’re right of course. After Brexit becomes fact it seems unlikely that we (= the continent) can convince you (= theUK) to drive at the correct side if the road .......LHD / RHD refers to steering wheel position.
UK drives on the left, so vehicles are RHD, and your earlier post references RHD lights.
hope that clarifies.
No need to remove the front end, changing bulbs is pretty easy even with man hands.
Just slide the battery to one side and remove the airbox cover, access is not too bad after that
It’s really easy with VCDS to make dipped beam stay on with full beam, it’s just taking a tick out of a box. Similar story to remove the bulb out warning too. Have a look on the forum member map for a yellow pin near you, they are VCDS users and can usually help.Can anyone save me removing my b***dy bumper and headlights for about the 100th time please. I’ve fitted all singing all dancing led bulbs to my Transporter HQ sequential head lights, only now I have the bulb out light on which I can live with until I get someone to Vagcom it but more annoying is when on full beam, one of my dip beam bulbs keeps flashing which is so annoying. If I pull back the flash beam so both full and dip are on it’s ok. So really I want to know
1. Is there something I can do to stop this
Or
2. Can a Vagcom put both full and dip on together when on full beam to stop this.
Thanks in advance for you knowledge.
Thanks for all that info that’s set mind at ease. Thought I’d give myself agro there. I think moving the air box and battery maybe the option if I ever have to get in there again.It’s really easy with VCDS to make dipped beam stay on with full beam, it’s just taking a tick out of a box. Similar story to remove the bulb out warning too. Have a look on the forum member map for a yellow pin near you, they are VCDS users and can usually help.
You can get the bulbs out without removing anything else, but an inspection mirror helps so you can see what you’re doing. It’s even easier if you pop the top of the air filter box off and move the battery out the way. That’s less hassle than bumper off. Did your LED bulbs come with canbus error resistors? My Phillips ones did and I had no bulb out warning.
