Now what is needed is a mini duct to blow air over the resistor once the blower is operated to keep it cool.
I'd say it is only speed/stage 3 that can blow the fuse. As above the current to the blower travels through the fuse only at switch positions 1-3.That looks like the one @Pauly , 4pin including thermal cut-out.
N24 - Fresh air blower series resistor with overheating fuse
fed from -
J301 - Air conditioning system control unit
restive load for blower motor stage 1,2,3 and direct feed for stage 4.
As to whether something like that would be suitable for integrating with the T6 electrical system I don't know, I suppose it would need to be part of the design right from the start.
Taking the temperature at the various speeds would be more informative.
The resistor pack sits in the main blower air flow duct for cooling. I have suspected the problem is the resistor pack getting too hot on speed 1 - so less air flow. Mine have always failed when on speed position 1.
But we are not worried about the current here surely? It is a thermal fuse and the resistor will get hottest on position 1. Taking the temperature at the various speeds would be more informative.
As the overheating fuse reacts to excessive temperature and not to excessive current I am convinced that this problem is down to the quality of the fuse itself.
Mine was always left in position 2!!! Let's see how long these last me..
My wife’s Ford Fiesta blows the resistor pack about once a year. It’s a common theme on various cars
Seems to be becoming a bit of a common issue this one,
fed from -
The thermal fuse may be the symptom rather than the cause, it could be there's a design fault in the resistor pack, or the blower, or the positioning of the fuse, that's causing the overheating. Like you say, it's a shame they don't give a toss and just swap it out instead of identifying the issue and modifying the part - it's been an issue for over 10yrs and carried over from the T5.
