Thursday,29,April,2021,20:09:28:07176
VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 RT HW: 04L 907 445 M
Component and/or Version: R4 2.0l TDI H01 9970
Software Coding: 001940144356050900000000000000000000000000000000
Work Shop Code: WSC 00012 790 00172
ASAM Dataset: EV_ECM20TDI03004L906056RT 005004 (VN46)
ROD: EV_ECM20TDI03004L906056LE_005.rod
VCID: 90725B854AE2330B9F3-80C4
2 Faults Found:
27277 - System Voltage
P0562 00 [035] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 3171 km
Date: 2021.04.21
Time: 00:08:45
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 22 °C
Intake air temperature: 0 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.328 V
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -0.20 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.000 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1015 mbar
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 4
Index of next requested engine mode: 7
Index of engine target mode: 7
25126 - Implausible Data Received from ESP Control Module
U0416 00 [035] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 3171 km
Date: 2021.04.21
Time: 00:37:03
Voltage terminal 30: 12.093 V
Acceleration: 0.000 m/s²
Average vehicle speed: 0.00 km/h
Cruise Control System (CCS): status: Initialization
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
03-ABS Brakes -- Status: Malfunction 0010
Thursday,29,April,2021,20:09:00:07176
www.Ross-Tech.com
Address 03: ABS Brakes Labels: None
Control Module Part Number: 7LB 614 517 B HW: 7LB 614 517
Component and/or Version: ESC_base H01 0800
Software Coding: 11554452C84EE687885B22A813686766393327B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012 (VN46)
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: BFD0A83927FCFC73369-80EA
1 Fault Found:
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:43
Thursday,29,April,2021,20:08:24:07176
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: None
Control Module Part Number: 2Q5 937 090 A HW: 2Q5 937 090 A
Component and/or Version: BCM T6PA Std+ H11 0943
Software Coding:
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 206001 (VN46)
ROD: EV_BCMA0_206.rod
VCID: B53CCA1115C03623EC5-80E0
2 Faults Found:
535060 - Databus
U1123 00 [009] - Received Error Message
[FLA_01 Datenbus empfangener Fehlerwert]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:48
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.9 V
592133 - Window Regulator; Front Passenger Side
B14D2 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:43
Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
0-Park/Steer Assist -- Status: Malfunction 0010
Thursday,29,April,2021,20:03:11:07176
www.Ross-Tech.com
Address 10: Park/Steer Assist Labels: 5Q0-919-298.clb
Control Module Part Number: 5QA 919 298 K HW: 5QA 919 298 A
Component and/or Version: PLA 3.0 12K H08 0073
Software Coding: 8351067941
ASAM Dataset: EV_EPHVA2CAU3700000 009055 (VN46)
ROD: EV_EPHVA2CAU3700000.rod
VCID: D8E263A5A2922B4B173-808C
3 Faults Found:
13637426 - Databus
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:44
13679386 - Databus
[Steuergerät für Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:43
13688835 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:45
13-Auto Dist. Reg -- Status: Malfunction 0010
Thursday,29,April,2021,20:04:20:07176
www.Ross-Tech.com
Address 13: Auto Dist. Reg Labels: 2Q0-907-572.clb
Control Module Part Number: 2Q0 907 572 R HW: 2Q0 907 572 B
Component and/or Version: ACCCONTIMQB H03 0372
Software Coding: 2A04600B01FF8748949C815560508700000000000000000004
Work Shop Code: WSC 00012 790 00155
ASAM Dataset: EV_ACCMRRCONTIVW376 003016 (VN46)
ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
VCID: C3D8A4C94B149893521-8096
3 Faults Found:
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:43
Voltage terminal 15: 11.8 V
Control Module temperature: 25 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.13 m/s²
Adaptive distance regulation: status: ACC_irreversible error
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:09:00
Voltage terminal 15: 11.9 V
Control Module temperature: 26 °C
Longitudinal acceleration: 0.09 m/s²
2055 - Databus
U1122 00 [009] - Implausible Message
[FAULT_ALP_STEERINGWHEEL_INIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:43
3C-Lane Change -- Status: Malfunction 0010
Thursday,29,April,2021,20:05:05:07176
www.Ross-Tech.com
Address 3C: Lane Change Labels: None
Control Module Part Number: 2Q0 907 686 B HW: 2Q0 907 686 B
Component and/or Version: HRE3_Kl15_Mst H06 0150
Software Coding: A2954640
Work Shop Code:
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001 (VN46)
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: B924C62139D8D24308D-80EC
2 Faults Found:
2236417 - Databus
[databus unreasonable message - LWI_QBit_Lenkradwinkel]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:45
2236426 - Databus
[databus unreasonable message - LWI_Lenkradwinkel]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:45
44-Steering Assist -- Status: Malfunction 0010
Thursday,29,April,2021,20:06:37:07176
www.Ross-Tech.com
Address 44: Steering Assist Labels: 2N0-909-143.clb
Control Module Part Number: 7LA 909 144 F HW: 7LA 909 144 D
Component and/or Version: EPS_MQB_ZFLS 751 7150
Software Coding: 1306
ASAM Dataset: EV_SteerAssisMNB 002012 (VN46)
ROD: EV_SteerAssisMNB.rod
VCID: C5DCBAD14520A6A37C5-8090
1 Fault Found:
16128 - Steering Angle Sensor
B1168 F2 [047] - Not Initialized
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:43
Motor status: 00
System status: Waiting for start request
Supply voltage: 11.75 V
Temperature: 15.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Thursday,29,April,2021,20:07:26:07176
www.Ross-Tech.com
Address A5: Frt Sens. Drv. Assist Labels: None
Control Module Part Number: 2Q0 980 653 B HW: 2Q0 980 653
Component and/or Version: MQB MFK 3.0 H13 1202
Software Coding: 00010908007AC020509F00000030002006018000000000000000000000000000
Work Shop Code:
ASAM Dataset: EV_MFK3ValeoMQB 007042 (VN46)
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: B43AF7151EBA2F2BDBB-80E0
5 Faults Found:
1135140 - Databus
[APS_03_US_Fehler_HS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:45
1135139 - Databus
[APS_03_US_Fehler_VS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:45
1123157 - Databus
[LH_EPS_03_EPS_Berechneter_LW]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:44
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:44
1123077 - Databus
[LH_EPS_03_EPS_BLW_QBit]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 3178 km
Date: 2021.04.21
Time: 00:08:44
