Hi thanx for your reply the only reason i ask is I've wired it all up and it works fine without them conected.The red cable is to identify a smart alternator. If you have one (on a T6 you do). Connect it to ignition live. And fuse in the centre row of the fuse box will give you this. The black cable is used to identify the type of leisure battery you have. Leave it disconnected for lead acid or ground it for AGM
Does it make a difference.
