P
Phil_G
Guest
I would, yes. It would give your controller a proper reset and a clean boot up.does that mean I would need to disconnect the solar panel again and re-attach it, so it can re-boot itself with a stable power source?
Either disconnect one wire from the solar panel, or just throw a heavy coat/blanket over it. Disconnect the battery pos. Leave it a minute.
The appropriate fuse is a convenient place to disconnect.
Cleanly reconnect the battery, ie make it one swift contact. Give it a minute then check your bluetooth stuff. Then let the solar through and look for panel voltage on bluetooth - probably not much today. Your converter should have a resistive floating power supply for testing solar controllers, but I bet he doesnt (around 18-20v at min 4Ω).
