Just bought our first Van. Twin slider Kombi. First day of rain and, yep, both windows leaking like seizes.
It's past its warranty though so trying to figure out how to sort this myself.
Bit of investigative work tells me that:
1. The drainage hole next to the red arrow is not blocked. If I syringe water into this hole, most of it runs down the ourtside of the door. Yeah, 'most of it'. Some finds its wat down the inside of the door. I'm thinking though that this drain is secondary to the slot drain highlighted in yellow.
2. The thin 'slot' in the window runner channel (highlighted in yellow, shown with a tool inserted for cleaning) is not blocked and water injected here finds its way to the outside of the door without any leaking inside the door.
3. The interesting thing is that, while the window is busily leaking, neither of the drain holes (marked 1 and 2) have any water around them at all. I'm fairly sure the issue is that the water is simply finding it's way between the seal where the slider assembly is bonded to the window. I've attempted to highlight this in green. So, none of it actually reaches the drains anyway.
I mean, wow, don't these windows have a multitude of exciting ways to fail?
Anyway, looks like my best shot is to do two things:
Remove the sliding window and clean the rubber seals on the sliding window itself. Hopefully this will at least reduce the amount of water coming in. The seals are very dirty so I suspect this will help a bit.
Then I need to improve the seal where the slider assembly is bonded to the glass. I'm going to try the 'Captain Tolley’s Creeping Crack Cure' product mentioned in a previous post. If that fails then I'll move up to proper glass bonding product.
Hopefully, at that point any water that does get in will at least find its way to the drains and I can start to debug the next bit of the puzzle!
Anyone got any thoughts on the approach I'm proposing here?
