silentwitness
Hi there.
With regards to the above diagram how is the distribution board controlled? Does it have switches like a control panel or is it literally a junction box?
My immediate thoughts are that you won't be able to turn the lights off if the doors are open or have been opened unless you turn the ignition, lock the van or wait for it to time out. Happy to be corrected as its been a while since I worked my lighting out. Admittedly this isn't a massive issue but it may not be what you are after.
Hiya, thanks for the reply. Yes the distribution box has a control panel where the circuit those lights are on can be turned off, or all the power to the lights can be switched off at a main switch.
However thinking about what you've said - would it work better if the OEM positive went to the normally open position and the power from the CBE distribution box goes to the normally closed position?
