Stop it now!
Isn't the Ctek 250 almost there? It sorts out the alternator & solar, just leaving the MHU charger, which is in parallel with the Ctek.All good points and also if you have any sort of regenerative braking/smart alternator then VSR, intelligent relay or ECU controlled relay systems are just no longer appropriate.
Roll on the holy grail of B2B/Solar/mains charger all in one nice unit. Or better still a modular system with a common control bus.
If you did then combine such a unit it would be able to charge both sides of the B2B on mains and keep both batteries charged up nicely when on hook up.
Not really, it's a bit behind the curve in terms of performance.Isn't the Ctek 250 almost there? It sorts out the alternator & solar, just leaving the MHU charger, which is in parallel with the Ctek.
Got this one now Loz Electrics | Travelvolts
They are excellent items but I always find it difficult to locate combined items because of their size. It is always easier to locate two smaller items in the available spaces under the seats. As with all engineering, it's a compromise! If you have the room then go for it.wow. what a discussion here.
travelvolts can I pick up your brain on with one more question: what is your view on multidevices like charger/inventer? I was given an advice to buy Victron Energy Multi 12/500/20-16 230V instead of the inverter I originally mentioned. What is your view on that?
Thanks, Beata
Is the the bees knees of split chargers then? I'm about to buy one for my T6. I plan to install two leisure batteries, ideally under the passenger seat. However unsure which charger to go for? Plus where will it all fit? ha!
I'd like the option of the split charging (or bluemotion dc to dc equivalent) but I'd also quite like to be able to plug into 240v in the rare occasion but would like to have it anyhow.
For a two battery set up I recommend the Redarc BCDC40-LV. You can fit the batteries, one under each seat and the Redarc alongside one of them. I will post some pics later of a similar set up.
It's probably the "100 Amp" solar panel wot killed itmy ring b2b has given up the ghost after a couple of years of iffy service,not sure if the discharge has damaged my two 110ah batteries and we are going away in the van for a week at the weekend aaaaarrrrrrgggghhhh.would the redarc 1240lv with wiring kit be ok with two batteries and a 100amp solar panel? thanks
I had to read that twiceIt's probably the "100 Amp" solar panel wot killed it
Yes, perfect!my ring b2b has given up the ghost after a couple of years of iffy service,not sure if the discharge has damaged my two 110ah batteries and we are going away in the van for a week at the weekend aaaaarrrrrrgggghhhh.would the redarc 1240lv with wiring kit be ok with two batteries and a 100amp solar panel? thanks
Consumer unit will fit in front of one of the batteries. For more info on routing cables visit our website and download the fitting PDFs from the product pages.@travelvolts Okay thanks! How would you then get 240 input to it? Via a ctek charger or similar and then have separate plugs some to an inverter off the lesuire batts and some to 240v mains in only via consumer unit perhaps. Best way of doing that?
Consumer unit will fit in front of one of the batteries. For more info on routing cables visit our website and download the fitting PDFs from the product pages.View attachment 24526 View attachment 24527
