I would love them from a capacity/technology point of view, but they scare the hell out of me..
our house is full of them
Our 100Ah lithium isn’t smaller, or if it is it is marginal. However it has a greater current output so can support the inverrter and also I understand they can be drawn down to a lower level of charge, so giving a larger effective battery for a rated capacity.The thing I don’t understand is, like-for-like capacity, they don’t actually seem much more compact than traditional leisure batteries.
Also, have a very large pile of moneyAs above LifePO4 is the chemistry to go for. A mate of mine has been a vehicle safety engineer all his working career and has done all sorts of destructive tests on battery packs.
He’s more than happy to go for LifePO4 as a leisure battery. Just have some voltage and current fail safes and you will be fine.
Victron sell all the kit you’ll need to keep your batteries safe
Think you've misunderstood @Davenjo , he said his existing lead acid battery only has about 2 yrs of life left, the LiFeP04 batteries should last way longer than the lead acids so at a price point of £699 they start to become much more viable if you keep the van long term. I saw this one on a stand at the Motor home show and thought at the time I hadn't seen one that low before.So....... to use your 2 years + life, you are prepared to put £699 up vs at least 12 years with normal batteries? I know where my money would go. As an engineer, I don't chase technology and allow technology to develop and costs to go down....![]()
One thing that does worry me a bit it the not being able to charge below 0 degC as the temperature in an unoccupied van could get below this in the depths of winter and the early morning sunlight could start the solar charging before the temperature gets above freezing??
Mine is just sat under the driver’s seat - no room for insulation.In some Caravans and Motorhomes, they overcome any issues with charging and external temperatures by housing the battery in an insulated cupboard, or inside a vented battery box.
Doesn't this happen on campers?
What would happen if my solar panel started trying to deliver a charge to the battery whilst it was still below 0 deg c?Temperature isn't too much of a problem. You just can't charge them below 0 degC. You CAN discharge them down to about -20DegC I think.
Most people south of the border don't need to worry about this as long as you have a temperature cut out on your BMS.
I'll just fit a small heating pad in my big systems to kick in before they hit 0DegC.
