For the Valence USB cable.
you need this cable USB > RS485:
Free delivery and returns on eligible orders. Buy USB Rs485 Adapter Cable Rs485 Converter Cable with FTDI compatible with USB-RS485-WE-1800-BT at Amazon UK.
amzn.to
EDIT: new connectors and boots added.
This TYCO AMP connector:
Waterproof Electrical Connector Plug Socket Male and Female 1.5mm Series Terminals Heat Shrink Quick Locking Wire Harness Sockets 1 Pin 2 Pin 3 Pin 4 Pin 5Pin 6 Pin Way 10 Kit (5 Pin): Amazon.co.uk: Car & Motorbike
amzn.to
2 3 4 5 6 way pin TYCO AMP Superseal Waterproof Connector Rubber Boots Sleeve
2 3 4 5 6 way pin TYCO AMP Superseal Waterproof Connector Rubber Boots Sleeve | eBay
SALE 2 3 4 5 and 6 Way TYCO AMP Superseal Rubber Boot Sets SALE. Suitable for Cars, Motorbikes, Trucks, Caravans, Machinery, Boats and other marine vehicles and all at the best prices. You will receive 2 rubber boots one for the male connector and one for the female connector for each item ordered.
rover.ebay.com
Tyco AMP Electrical Waterproof Connector 1 2 3 4 5 6 Pin Superseal Car Boat Kit | eBay
1 2 3 4 5 and 6 Way Waterproof Electrical Connectors SALE. Sealed Waterproof Connectors. 1 X Male connector housing and insert 1,2,3,4,5 or 6 way. 1 X Female connector housing and insert 1,2,3,4,5 or 6 way.
rover.ebay.com
and these conections:
VALENCE software:
Here is a link to download a zip file containing the valence software to connect the laptop to its onboard computer. This one has three tabs in the bottom section and I heard there is a version that has four tabs if you know where I can get it let me know. It's for Windows only and will not work with Apple unless you run Windows in a virtual machine on your Apple with all kinds of hassle. If you're not plugging the batteries into a laptop I would suggest plugging the two communication cables into each other on the same battery to form a sort of handle that you should not lift the battery with. This will keep the metal pins inside the connectors clean and corrosion free. When you open the software after you install it you'll need to find the ModuleDiagG2.exe file in the program's folder (x86) folder. Right click on it and run as administrator. On my computer I was not able to right click on the desktop shortcut to accomplish this. Now you should have the valence program running and you'll see the main valence page with mostly blank boxes.
Next you need to set the logging path in the battery info tab. Near the bottom right side click on browse and choose a place somewhere on your computer probably in my documents folder you can create a folder called valence log files or something and choose that folder. Every once in a while like if my laptop goes to sleep and then wakes back up again I noticed the data reported in the software no longer reflects the correct battery when I switch between batteries. If this happens I simply restart the program and it's good to go again. If anyone knows how to write some basic code so that we can see the info on all the batteries on a live active spreadsheet that would be great if you help me out with that I'll share it with everyone.
Valence software-20191020T204520Z-001.zip
COM PORT:
Now about choosing the comport. In the valence software click the comport drop down and you'll see that it's blank. There are no comm ports to choose even if have you previously set up the comport properly. You'll have to go to your hardware page to discover the com number. Then go to the software and literally type com7 or com5 or whatever the number was. And remember no spaces. Next look at the ID number I wrote on the battery and choose that in the drop-down. Connect to the communication wire from the balance computer into the rs485 USB adapter Then click start communication. You should now be seeing all the boxes filled with data from the batteries onboard computer. You can switch between batteries without ending and restarting communication but it only shows one battery at a time which is kind of annoying.
source:
Valence XP Super Thread
