Oh, thanks for letting us know.
I understand the advice, playing "parts roulette" (replacing parts until you cure the problem), isn't always a great idea, but when you don't have a fault code to help it is sometimes necessary. If the garage can see that you've had several failed dpf regens at least that's a start. I'm not convinced that that's the problem, but hey, they're the experts, hopefully.
On my 6 speed manual I have enough trouble driving at over 2 thousand revs to try to help it regenerate, that's over 70mph in sixth gear, so I sometimes stay in 5th if I know it is regenerating, which goes against all my instinct because I like to use the taller gears to save revving the engine too much. (Surely that's why we've got six gears!) Now you've been told 3 thousand revs for half an hour, I think that would be quite unpleasant!
What they said about the ECU having to relearn is not credible, when you replace a dirty air filter with a clean one it "relearns" with no problem at all and the improvement in performance is immediate! People clean EGR valves and have no such problems!
Hopefully you will get the van back running perfectly, let us know!
