On Mine I had to apply the second one.Yeah I think so... Not too worry though. Head unit out now to save the battery and parts ordered.
Wondering if the second 478T firmware files is a pre-requisite for skins? Prob explains my error!![]()
[cpu\onlineservices\2\default\Dir]
Link = "[cpu\onlineservices\1\default\Dir]"
[cpu\onlineservices\3\default\Dir]
[cpu\onlineservices\4\default\Dir]
[cpu\onlineservices\5\default\Dir]
[cpu\onlineservices\6\default\Dir]
[cpu\onlineservices\7\default\Dir]
[cpu\onlineservices\8\default\Dir]
[cpu\onlineservices\9\default\Dir]
[cpu\onlineservices\10\default\Dir]
[cpu\onlineservices\11\default\Dir]
[cpu\onlineservices\12\default\Dir]
[cpu\onlineservices\13\default\Dir]
[cpu\onlineservices\14\default\Dir]
[cpu\onlineservices\15\default\Dir]
[cpu\onlineservices\16\default\Dir]
[cpu\onlineservices\17\default\Dir]
[cpu\onlineservices\18\default\Dir]
[cpu\onlineservices\19\default\Dir]
[cpu\onlineservices\20\default\Dir]
[cpu\onlineservices\21\default\Dir]
[cpu\onlineservices\22\default\Dir]
[cpu\onlineservices\23\default\Dir]
[cpu\onlineservices\24\default\Dir]
[cpu\onlineservices\33\default\Dir]
[cpu\onlineservices\34\default\Dir]
[cpu\onlineservices\35\default\Dir]
[cpu\onlineservices\36\default\Dir]
just apply the skin again and it will workSo I rescued my head unit successfully, but my optical view doesn't play ball. Even though I have crafter on the screen now. Am I missing something?
Irrespective I now have sport mode, off road, think blue etc though.... not a bad swap![]()
just apply the skin again and it will work![]()
You have to recover due to the skin?I had to recover the unit again. Interestingly though on version 2xx I noticed the proximity display wasn't showing, so I think I've ballsed up somewhere in obd
I can only apologise for that, I'll delete the non working one!Yeah obtain a few from previous posts and decided to try.
The second 478T patch with Skins fix was fine, it was the last skin pack I had that broke my unit #notetoself
Anyone with optical parking kind to share a VCDS adaptions channel map? I need something to compare against.
Installed SW Train Version
MST2_EU_VW_PQ_P0468T
Installed SW MU Version:
0468
Partnumber:
5C0035680G
Installed Codes:
00040100 - Navigation
09400008 - Map Europe
00070200 - Voice Control
00050000 - Bluetooth
00030000 - USB
00060300 - Mirror-link /App-Connect
00060800 - Apple Car Play
00060900 - Android Auto
00060100 - Vehicle Interface
00060200 - Car-Net
00070400 - Electronic amplifier for driver
Supported Codes:
00040100 X - Navigation
00050000 X - Bluetooth
00060100 X - Vehicle Interface
00060200 X - Car-Net
00060300 X - Mirror-link /App-Connect
00060400 - Performance Monitor/ Sport HMI
00060800 X - Apple Car Play
00060900 X - Android Auto
00060b00 - Baidu Carlife
00070200 X - Voice Control
00070400 X - Electronic amplifier for driver
07400024 - ???
08400002 - DB_EU_MIB_STD_GEN2_SKODA_22_15
09400003 - DB_EU_MIB_STD_GEN2_VW_45_15
0c400003 - DB_EU_MIB_STD_GEN2_MAN_SOP1WV2ZZZ7HZJH127144
I got the same problem. do not replace the skin using the patch (bad checksum!). use the customization script from mib tool instead!Yeah I think so... Not too worry though. Head unit out now to save the battery and parts ordered.
Hi Steffen,hi all,
I've been reading along for a while now, but with no advice I've been able to unlock the "Vecile Monitor" on my device.Its still on "original T6" Firmware 4.78 (MST2_EU_VW_PQ_PO478T)
I tried to enable "BordComputer" as well as "Sport HMI" via VCDS without success. After enabling "Hybrid menu" i got a (the respective) new Menu entry which, after selecting, just showed "starting vehicle mode" and nothing more.
The main questions I'm not clear about are:
-> Am I able to activate "vehicle menu" on my original firmware by using VCDS or Toolbox only?
-> or is it needed to change any skin or add any swap / fec to the unit?
EDIT:
Just noticed, that my unit seem to miss (needed?) FEC 60100. Its currently available but not installed. I guess i need to "install" it first and then activate through VCDS or Toolbox?
thx for your support, kind regards
Steffen
Hi Steffen,
I had the same problem. Lot's of information and missing the whole picture.
Vehicle Status menu:
The problem is that the T6 Skin does not have the files for those menues, so the HMI Software is not activating it.
The solution is to change the vehicle model skin with VCDS to the VW Crafter one, as it has the necessary files in it.
You will have a Crafter image showed in the menu but at least the menu is now active.
Nexts steps is to extract the images and replace them with yours.
This will need time and patience.
