MIB2 PQ Discover Media - Infotainment mods, upgrade, FEC / SWaP
A backup admap and scan of the unit? I'll give it bash. I'm optimistlciy hoping I might be able to get "Vehicle status" to show on the radio but its highly unlikely
That's my target aswell. Will try it in Golf 6 with colored MFA and Passat B7 again. Will give feedback if there are some news
Hi folks,
Pls help me to remove CP, I have installed in Vento (India). I have VCDS and VAS5054A will it help?
No won't help, CP off can be done during Update, but there will remain 2 faults in Device. Maybe I can create special update for you if you tell me your version
about admap
so i compare different postings admap from here.
f.x. 117676 and 117762 shows you START/STOP
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
Does BAP meas Protocol from cluster unit?
Why they are in two different entrys?
thanks for answer
Does you have a clue yet?
If i activate Hybrid i got CAR Menu.
But if i disable HYBRID again, it will not stay in Menu
What i do wrong?
@Adams (5C0035680G, SW 0449, 60100 installed) and
@mmi (5C0035680F, SW 0468, 60100 not installed and not present)
can you both perform simple test for me and post your findings/results here?
Each step is quite important so please be pedantic:cool:
1. Change your infotainment adaptation channel
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid to activated
2. Check if you have new entry in the main menu called "HYBRID".
3. If yes, click it and enter your new menu entry(as our vehicles are not hybrids there is nothing really useful)
4. While you are still in that menu change the same adaptation channel
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid to not activated
Now you should see something like below
5. Press on the screen bottom RHS car/gear icon and enter configuration menu(just for the purpose of entering that sub menu, you will adjust things later on;))
6. Exit configuration by pressing top RHS twisted arrow icon once.
7. Click bottom LHS Selection icon and see what shows up there.
8. Do whatever you like, check everything, enter/access/modify/adjust :thumbsup:
After ponit 4 and restart radio this entry is gone from Menu.
Any help?
Hello, I am new here... Can you help me? I would like enable some codes and functions as voice, car menu etc. in my car. How I can do it? (without autorized dealers) Thank you very much for any informations. I can only activate offroad screen with pressed voice+menu+nav. John
Hi Jan,
What's your HW and SW version?
Ideally full VCDS info read would be handy.
As promised, an update:
Performance monitor activated, vehicle status already showing as "active" in the lists as per previous posts. However, the gauges all display 0 readings, as does the steering angle on the off road mode.
New menu items, then click into each spoiler to see under that menu
I've also posted an admap of the radio for anyone whos interested!
Finally, I'm trying to work out where the radio gets thedriving data from, if its the gateway or the clocks. I think its the clocks, so I'm working on finding a set of 3D clocks to pair with it and hopefuly get everything working.
Hello, how I can activate Vehicle Data and Driving status?
You could check with your local VW dealership and see if they can activate 60100 - Vehicle Interface for you.
My local dealership was useless in this respect.
Alternatively ask @Jester and I am pretty sure he will have a solution for you.
Thank you, I am far from any dealership but I try ask Jester :)
John
Hi Robert, first i will like to thank you for all those tips to get shown the hydrid skin ;), I did follow yourn steps and i got the new menus shown, but i'll like to ask, how can i get the menus fix. because when i change the menu_display_hybrid to not activated back, then i see the skins anymore, ist there a way to get the all that steady??
THX in advance :)
Solution with menu is easy. You have just to bring chinese firmware skin folder in device. Then you have the MIB2.5 skin with 8 tiles. Then you have tile for Car menu and you can access these menus without any diagnostic software also you have to change a value in txt file. But if you do wrong Unit is in bootloop and you`ll have to recover it.
Another update for you all, because why not.
Set of colour 3D clocks fitted today. As predicted, this now carries the data from the trip computer to the MIB unit.
Still nothing on the sports display, or steering angle on offroad. Car status still a blank screen from the menu.
I managed to pick up a new gateway at the same time,latest software (BR verision) so once that arrives, it will be installed and we shall see what happens.
On a side note, the premium cluster has given me extra readings such as oil temp (in the cluster, not the radio) and a "refuel" reading which measures in gallons.
Hello, how did you make it? I have no car menu but I have same MIB unit
