So here is the main dealer assessment. I would be very interested in your valued opinions on best way out of this
"When investigating the vehicle for a potential miss fire, at first there was no engine warning lights on, therefore nothing to go by to begin diagnosis. We started off by carrying out a road test on the vehicle and whilst we were on the road the vehicle was bellowing out black and blue smoke from the exhaust, which indicates oil burning and over fuelling. On return to the workshop we repeated the tests that had already been carried out by another garage, so when testing the return flow of the injectors 1,2,3,+4 the readings at idle after 2 minutes were between 20/25ml where the limit is 25ml, so all injectors on an idle test were on the maximum limit. Flow rate test carried out again at fast idle for 2 minutes where the maximum limit is 65ml and injectors 1,2,3,+4 resulted in being between 70/75ml and are deemed un serviceable. Advice from our technical support team is, if all injectors have failed the return flow rate test then there is an underlining issue with the fuel system, the main components that cause this issue is partial break up of the high pressure fuel pump internally, which intern causes swarf to go around the fuel system and block all the major components. We have checked the fuel within the tank and there is no obvious sign of metal particles in the fuel but they are not always clear to the eye as it only takes shavings to cause the problem to begin with. Following this we carried out a cylinder compression test where the compressions can not be any more than a maximum of 5bar difference between cylinders with the pressures needing to be around 19bar pressure minimum across the 4 cylinders. Results from test were as follows CYL1=10.2Bar, CYL2=16.9Bar, CYL3=18.2Bar, CYL4=17.2Bar. As you can see there is a difference of 6.7Bar pressure between cylinders 1 and 2, yet cylinder 1 is also extremely low, with the pressure being this low it is evident that there is a significant engine issue internally. Our suspicion is putting all our findings together is that where the high pressure fuel pump has internally failed it has caused the injectors to block allowing excessive amounts of fuel to return and cause over fuelling where the unburnt fuel is then washing past the bores causing a potential hydro lock which may have bent cylinder 1 con rod, it will also cause the oil level to rise and exit through the exhaust ports and causing consequential damage to the catalytic converter and diesel particulate filter also."
