The shitty engine designBut which came first? The chicken or the egg?
My '67 plate 204, 55k, hi line kombi has just had the engine, dpf & Cat replaced by Listers in Droitwich almost free of charge & it was out of warranty !
I noticed a month or so ago it was burning oil, 600ml in 1k miles. It was due a minor service so we did an oil consumption check. I did 700 odd miles, took it back for them to weigh the oil. Sure enough it failed, so was informed it needed a new engine, dpf & Cat.
At 3yrs old I bought a VW warranty but it only covered £2.5k of work & only covering total failure, it's all in the small print ! So Listers informed me mine wasn't the first they'd had this problem with & said they'd talk to VW about it as I was a valued customer (spent £95k on van's since 06).To my utter Amazement VW agreed to cover 100% of materials & 50% of labour. The service department also spoke to the warranty company & they picked up the other 50% of labour costs (£250 excess to pay)
I was so relieved, was going to have to organise finance to cover the £10k cost ! They fitted a new half engine, so I had to pay for a new cambelt & water pump, reused my head, a new DPF & CAT. Cost me £322 for belt & pump & £250 excess on warranty. Thanks to Brad at Listers, I really dodged a bullet.
The problem is the EGR on the bi-turbo model, 204bhp. It leaks fluid into the cylinders & damages them. Dealerships know about it, VW obviously know about it but they're not publicising it.
I read your thread when I had my problems & really wanted to contact you. I hope this information is helpful to you. I don't know who supplied your Van but Listers have really stepped up to the plate for me & wouldn't buy a van from anywhere else now. Best Wishes Ian
That is interesting, but I’m really curious as to the EGR differences between 150 and 204/199, and exactly how fluid (and what fluid) leaks into the engine.Interesting thread started by @Ian Blewett today - good of him to be so helpful , this may shed a little more light on what happened. I need to keep on digging as it looks like there may be a known problem that's being suppressed. Must admit it's all rather frustrating that I have yet to feel confident that I've really got to the bottom of this yet.
There’s only one liquid fluid in the EGR unit, engine coolant.That is interesting, but I’m really curious as to the EGR differences between 150 and 204/199, and exactly how fluid (and what fluid) leaks into the engine.
Maybe for another thread though.
Good to get the final diagnosis and I’m sure your glad it’s over.@dubLU thanks for the prompt - I'll update you all on what finally happened. I ended up having the engine rebuilt by Dragon Engines in Chesterfield who were fantastic even though it took them a while. But they checked and tested pretty much everything and only replaced what needed to be replaced unlike VW who wanted to replace everything. Having had them recommended I had my van relayed to them and they finally had the engine out and apart. They confirmed that fuel contamination was the root cause and after having had the fuel pump tested found that had started to disintegrate sending all sorts of stuff through the fuel system wrecking that, the injectors, washing the bores, hydrolocking and bending a rod on No1 cylinder.
Realising that this was going to go nowhere with VW as it was an external factor, I gave up any hope of VW contributing in any way. I then asked Dragon to make sure anything that was affected be sorted out properly without any shortcuts risking further issues. So they ended remanufacturing the engine, which I believe is new bottom end, pistons, rings, rods etc, new fuel pump, new fuel rail, new injectors, new glowplugs and they also found the EGR was faulty so replaced that. At the same time they replaced the cam belt and waterpump. The dpf was also cleaned as they have a means of doing that too. The bill was pretty eye-watering but it was half the price of what it would have cost if I'd gone the main dealer route. So whilst it stung like crazy I still feel like I maybe got off lightly.
The van now effectively has a new engine, runs perfectly again and at least I have a year's warranty. Saga over at last. Hats off to the guys at Dragon, when I went to pick the van up it was clear they have a lots of failed engines to deal with, as the AA trucks kept rolling up, but I felt they advised me wisely, had obviously seen this a lot before, and whilst the costs mounted up I never once felt like I was being seen off as they always looked for the most cost-effective solution within the parameters of ensuring the engine came out the other side as reliable as possible. They did mention that the more recent the van, the more they see of them, basically because of all the emissions stuff creating problems. They said that basically the engine is sound but as you bolt more emissions devices and systems on you get more trouble from them.
Love your forensic-like, engineering brain @DXXGood to get the final diagnosis and I’m sure your glad it’s over.
As the fuel analysis was within specification it would appear that the fuel didn’t cause the HPP breakdown, at least not the fuel that was in the system when sampled.
Was there any other work carried out on the fuel system in the months leading up to the breakdown, routine servicing, hoses disconnected etc?
I completely agree!You can’t prevent it happening again if you don’t know what caused it in the first place. No such thing as ’shit happens’ with machinery.
I always knew my '16 plate EU5 engine was the ACME for these vans ;-)They did mention that the more recent the van, the more they see of them, basically because of all the emissions stuff creating problems. They said that basically the engine is sound but as you bolt more emissions devices and systems on you get more trouble from them.
