OEM Webasto Auxiliary Heater To Parking Heater Upgrade
My aux heater details before flashing.
Code:
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273     HW: 7E0 963 273
   Component: STH-T5GP2     002 0007
   Coding: 4101
   Shop #: WSC 02759 790 50316
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 6ADB74A98D7FEE1A6B-803E
Control Module Part Number: 7E0 963 273
  Component and/or Version: STH-T5GP2     002 0007
           Software Coding: 4101
            Work Shop Code: WSC 02759
Advanced Identification/FAZIT
     Identification: WOS-000
     Date: 16.09.15
     Manufacturer number: 2450
     Test stand number: 0894
Flash Status
     Programming Attempts(application): 1/0/0
     Flash Date: 00.00.00
Misc.
     Hardware number: 7E0 963 273
     Workshop System Name: J364
     Equipment/PR Code: 000000000000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     ASAM Dataset Revision: 001010
VCDS Info:
       Labels: 7E0-963-27X-18.clb
My aux heater details after flashing(but before connecting Telestart)
Code:
   Part No SW: 7E0 963 272 B    HW: 7E0 963 273
   Component: STH-T5GP2     002 0009
   Coding: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   VCID: 2B55B1AD4205371250-807E
Control Module Part Number: 7E0 963 272 B
  Component and/or Version: STH-T5GP2     002 0009
     Date: 16.09.15
Flash Status
     Programming Attempts(application): 1/1/1
Misc.
     ASAM Dataset Revision: 001013
VCDS Info:
Aux heater flashing process with ODIS-Engineering;)
Reactions: mmi
My good wife :inlove: will be (should be:unsure:) quite pleased with my efforts when she'll get into warm vehicle tomorrow morning.
Coding: 4101
Date: 16.09.15
Flash Status
Misc.
VCDS Info:
Coding: 4101
Date: 16.09.15
Flash Status
Misc.
VCDS Info:
And also ODIS-Engineering comparison(before and after the flash):)
Reactions: mmi
To complete your now almost Nordic setup - an OEM control panel/timer working in parallel with remote.
18-aux_heat_webasto_overhead_control-jpg.20991
Added functionality:
  • timer (3 programmable times - time + week day -> max week ahead), however they are just one shot - can only activate the next event (can't activate repeats e.g. automatically every Mo-Fr at 6:15, need always to "authorize" the next one).
  • set mode: heat or ventilation only
  • set heat/vent time on remote (as in pic 30 mins)
  • child lock
As in MY18, MY19
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 J HW: 7E5 919 037 J
Component: Dachdisplay H17 0200
Revision: 1010013S Serial number: 62xxxx
Coding: 000103 (with remote, without 000102)
As in MY16, MY17
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185 . . . . . . . . . . . (EDIT: also found H15 0200)
Revision: 10100011 Serial number: 40xxxx
There is one side effect of this "retrofit" - one permanent fault in Aux. Heater (18).
0266 - Databus
U1121 00 [009] - Missing Message
[TIMEOUT mDachdisplay]
Luckily there are no practical consequences.
It appears that connecting Telestart unit without the overhead timer is the cause :whistle:.
Normally as a standard factory option the overhead timer always comes with Telestart.
Next step is to work out coding modification which will clear this fault :thumbsup:.
@Robert
Does the auxiliary coolant heater have it's own built in pump, to circulate the coolant or is it a stand alone unit somewhere?
Auxiliary heater doesn't have a pump built in and it uses existing OEM pump on the coolant circuit.
The whole preheating process is triggered by Telestart and then controlled by Aux. Heater (18)
which communicates via CAN with any other associated components.
I hope this answers your question somehow;)
Reactions: mmi
Is there an additional or uprated pump as opposed to the standard non aux heater pump?
0266 - Databus
Luckily there are no practical consequences of that fault.
It appears that connecting Telestart unit without the overhead timer is the cause:whistle:
Next step is to work out coding modification which will clear this fault:thumbsup:
Can confirm the cause. Disconnected my overhead timer panel - and as expected the same fault as above.
Did some coding experiments, however I didn't remove the "6E" from CANbus installation list.
Run basically through all the version codings + a few "unknowns" by changing the coding and then clearing the fault.
5800 = my current working coding, v1​
5808 (byte 1, bit 3)​
D800 (byte 0, bit 7)​
5810 v2​
5820 v3​
5830 v4​
5840 v5​
5850 v6​
5880 v1 + (byte 1, bit 7)​
5890 v2​
58A0 v3​
58B0 v4​
58C0 v5​
58D0 v6​
No luck with any of the above...:cry: - your turn now ;)
Once the Telestart is triggered remotely it produces 12V DC output on pin number 3 (green wire in my case). This then could be used as a ON confirmation signal. I don't know where to connect it, maybe horn:p:D:rofl:
Thanks Robert for this.
I'm fairly new here, try to get this done without a telestart module, but instead using an app-control(VW T6 - APP-control for water-heater)
My question: what signal is going to the white/green cable in the red connector(pin1): is it simple +12V, or is it W-bus/Lin?
Thanks,
Jaap Stomphorst
Thanks,
Jaap Stomphorst
Hi Jaap,
This is quite good idea although much more expensive.
Assuming that you are referring to this.
It is the Lin-bus cable which normally allows for communication between Telestart unit and actual heater(parking heater).
See below.
