OEM Webasto Auxiliary Heater To Parking Heater Upgrade
Thanks for your reply.
Is the CAN bus connection only for the coolant heater and the 4 non-CAN cables are for the Airtronic air blower?
Ie. There are 2 almost separate systems, or is the CAN bus used to coordinate combined operation?
Sorry if they seem like daft questions.
Air heater and water heater remotes work differently.
In case of water heater, CAN wires are connecting the remote to the car and controlling the heater via CAN.
In case of air heater, the CAN is used only to connect the remote to the car. The rest of the wires are used for controlling the heater by the remote.
Hope it makes sense.
What are you trying to achieve?
Reactions: mmi
Thank you for your reply @eugene .
I have an almost complete set of parts including the coolant heater and the air heater. They date from around 2016, but are very good condition.
I am working on fitting them to a 2020 model.
I have studied the diagrams and I am piecing togther the missing information.
Ideally I would like to fit the air heater part and then later the coolant part.
However I realise that they have some crossover - eg, the harness between the blue (right vehicle side) and red connector (left vehicle side).
So fitting separately might not be realistic.
The remote control feature is secondary to me at this stage / not bothered.
I'm basically understanding how it works so I can weigh-up my options.
I am almost certain you already have a water heater. Please check it.
Air heater from 2016 won't be compatible with 2020 car. I think connecting it to a remote will still be possible but it won't talk to the car.
So I suggest you make a harness for the air heater including the CAN wires. If this brings a load of errors, you will disconnect the CAN wires and just use the remote to control the heater.
I think it will be an interesting project.
Thanks @eugene
Yes I do have the coolant and the air heater.
Thank you for your ideas.
I will investigate further.
The set came with:
Matching centre roof display/control unit
Webasto coolant heater+ pipes
Eber air heater
Trims
Ducts
Pumps
Etc
Regards
Here is my video and brief follow up:
Parts used:
1x VW Overhead display control unit for Webasto parking heater 7E5919037J:
View attachment 93107View attachment 93108View attachment 93109
1x 16-pin Connector for Overhead unit 1K0972928:
1x Telestart Module 3Q0963513:
1x Set of wire and Aerial for Telestart module:
1x Remote Control for Telestart 3G0963511B:
Wire set. Cross section 0.35mm for CAN-bus and 0.5mm for +12VDC and GND.
(CAN-bus cables shall be twisted together):
All connections and wiring were made according to the diagrams published in this thread.
I used T17p red plug under the driver's seat to make connection for both Overhead display and Telestart module.
Could you please share the full scan damp of your system. I have the same set and would like to double check the correct coding.
