Get a good converter to work his magic, the result will be better than any Cali.Yep lol went to Dealership to buy a Cali ended up with a Van !!!! What the hell do I need a van for
I must admit I was not happy with a 2 years service option so pleased to have my oil and filter changed anywayThere are two service options so it depends how the van was programmed at the factory to be ie 1 year or 2 year servicing, either is acceptable and if its been set to one year you can go to your dealer and ask them to change it to two year intervals, thats what i did (but i do a 12 month oil change myself in between)
I was booked in to visit Exploria to look at having it converted, but decided that I am handing it back after 3 years when pcp ends. Worry about the Diesel effect on future values.Get a good converter to work his magic, the result will be better than any Cali.
Get a copy of the test report and get it tested yourself. It has to be VW 507 spec not just a 5W/30. If the wrong oil has been used you won't have a leg to stand on with VW and will have to seek civil action for damages against the garage. You only have to prove on the balance of probabilities that the garage used to correct oil.
Do you have PROOF that it was serviced correctly and in time? The services are not fixed at 20k, it's variable and going over by more than 10% of mileage over the specified service or by a calendar month will also nullify your warranty.
I put my reg into Opie Oils search box and it came back with a choice of 15 different oils, all 5W-30, all ACEA-C3, all to VW 507.00 specification.
What EXACT oil did your garage put in (Make & Model)?
https://www.opieoils.co.uk/f/2354/30218/2017/engine-oil.aspx
Yes, they are flagged - in the module 17-Instruments, as e.g.
@t6 steve - I've just seen you've posted this same query on a few different threads. Where did you buy the van from and was it sold as having a full service history? - you might have a course of action with that organisation. Can you take a photo of the last service receipt too so I can see exactly what was done too please.
The mileage/time service interval tends to favour the mileage, ie if you do 20,000 inside 12months you should get it serviced based on the mileage, if it does 8,000 miles in the 12months you should service it at the 12 months rather than now wait for the 20,000 mile marker to be reached.
It's a world wide issue that is written in all service schedules "whichever comes first"
hi and thanks heres a picture of the last service done thanks again steve@t6 steve - I've just seen you've posted this same query on a few different threads. Where did you buy the van from and was it sold as having a full service history? - you might have a course of action with that organisation. Can you take a photo of the last service receipt too so I can see exactly what was done too please.
