Hi!
I have an orange light with the engine logo.
I used VCDS to read error, and I imagine it's a pre-heat glow plug, seing the log.
Please, could you confirm? Is there any other possibility?
Thanks a lot.
Thanks a lot.
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KK HW: 04L 907 445
Component: R4 2.0l TDI H02 6187
Revision: 23002001
Coding: 0019401CC35601090000
Shop #: WSC 16179 004 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KK 004015
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 005A88B2EA81CD1A2F3-8054
VINID: 9E60AAAAA1D8A986000491C8001E1DE04F
1 Fault Found:
15918 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [10101111] - Electrical Fault
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 298391 km
Date: 2085.01.05
Time: 23:33:04
Engine RPM: 826.25 /min
Normed load value: 27.8 %
Vehicle speed: 0 km/h
Coolant temperature: 25 °C
Intake air temperature: 0 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.234 V
Unlearning counter according OBD: 40
Pre-glow time: 2.5 s
Glow status: Post-heat
Outside temperature sensor 1: B1: raw value: -16.5 °C
Readiness: N/A
