Nothing had changed.Sounds high for just an unused USB charger. Do you have an AMT12-2 as well? The pics you posted earlier show a draw of 1.8a on the BMS but only 0.22a in the shunt. What had changed between the pics taken only a few seconds apart?
I’m not 100% sure on how the DC-DC will act if the LB is isolated as I’ve not tried. It should see no LB voltage so may not try to start charging. But alternatively it may think the battery is totally flat so try to charge it - not sure if it needs at least a small voltage to try this - in which case there will be power at the busbars so lights would work. Or, is the Orion definitely in charger mode and not power supply mode?
Don’t go chasing the numbers. Get the LB fully charged (mains charger if possible) and datum the shunt SOC. Just use the system and check back in a few days. At the moment it’s been on, off and near, but not quite fully charged. You’ve unplugged stuff and switched things around. Just use it and cycle it and see how things go in a week. If you’ve now got the wiring sorted, the charger battery modes set correctly and the auto detection set right it should all sort itself out.
AMT will explain the different output between the pics. It will also go some way to explaining the usage overnight, especially if your starter battery is a bit low.Nothing had changed.
Yes to Amt 12-2
I’m not saying these are 100% the perfect settings but they are working well for me. The Fogstar website has details on their FAQ page for Victron specific settings - I’ve used those.
excellent! Yes, I think Amt propping up a very much last legs starter battery. Glad this seems more sorted nowAMT will explain the different output between the pics. It will also go some way to explaining the usage overnight, especially if your starter battery is a bit low.
I’ll check all mine tomorrowI’m not saying these are 100% the perfect settings but they are working well for me. The Fogstar website has details on their FAQ page for Victron specific settings - I’ve used those.
MPPT:
Orion (mine is a 30A but settings should be v similar). I’m on the default engine detection settings and they work fine for me:
Shunt:
