Hi Pauly.Yes still making them as/when required
Hi I cannot seem to get an answer on this.Yes still making them as/when required
@Pauly.Hi I cannot seem to get an answer on this.
I’m after the side door power latching kit.
If you don’t have them available that’s ok but could you supply me with the wiring/installation instructions for a fee and then I can by my own hardware?
Please let me know.
Thanks,
Mick.
Hi DaveyB.@Pauly.
@Mickm, Pauly will make them as and when requested, as per his comments in April. If you want to make sure he see’s your post/ question put the @ symbol before their name. Alternatively send him a private message.
Now that I have tagged him in, hopefully he’ll be along presently. He isn’t online everyday due to his work commitments, but should now be pulled towards this particular thread.
Whoop whoop!!!Helloits me
Will reply to your pm
Helloits me
while kids shitting the door and camping.
OopsThe kids have done what!!!! I wouldn’t be letting them back anywhere near the van if this is how they treat it.
You mean power latching in operation or the install ?Has anyone done any videos or have any photos of this - the while kids shutting the door and camping has convinced me but I’d really like to gauge it and see if the conversion would hinder my access.
Are you still doing these kits???You mean power latching in operation or the install ?
PM sentIf you send me a pm I will send you some photos, the wiring is all easy/ plug and play you just need to cut a single wire under the passenger seat and connect it to the supplied loom and add a 12 volt supply from somewhere
You will need access to rear quarter panel then the roof void as the cables run fromrear up d pillar over roof and down b pillar
Next video @Dellmassive ?Hi - the install - not sure it’s my bag but def would like it so need to see how involved it is or outsource the fitting
@PaulyIf you send me a pm I will send you some photos, the wiring is all easy/ plug and play you just need to cut a single wire under the passenger seat and connect it to the supplied loom and add a 12 volt supply from somewhere
Yes, you still have to shut the door but with a lot less force as it does the final bit for you
